Old March 16, 2011, 05:01 AM
Default Driver cleaner / sweeper
Hey guys. Finally getting rid of my 5770 for a 560 oc. Just wondering what utility you use for driver cleaning and the general process you go through.
Do I intall the new card then run the utility or run it before installing the new card?
A link to a trusted util would be super too as there are soo many results from google it's mind-boggling.
Running win7 64 ultimate BTW Just in case there are ones that don't run on it..
Old March 16, 2011, 05:27 AM
CMetaphor's Avatar
Quadfather
My method (which has worked where other methods have failed) =
1 - Uninstall the driver from windows via add/remove
2 - Uninstall the driver from Device manager
3 - Restart into safe mode
4 - Clean using Driver sweeper
5 - Clean the registry using CCleaner twice (it doesnt catch everything the first time)
6 - Turn off the PC, swap cards.
7 - Reboot into windows (normal) and install the latest/greatest.
Hope it helps!
Old March 16, 2011, 06:40 AM
Thats brill cheers.. Best place to pick up ccleaner?
Old March 16, 2011, 06:56 AM
CMetaphor's Avatar
Quadfather
http://www.piriform.com/
Old March 16, 2011, 07:19 AM
On2wheels's Avatar
Also thanks to CM.
"Crap Cleaner" program? Polygon Off Topic 17 November 1, 2010 02:12 PM
Best registry cleaner? Neolithium_Wpg O/S's, Drivers & General Software 10 September 8, 2009 11:38 PM
OMG help!! Impossible Mine Sweeper...? howdid Off Topic 4 January 11, 2009 04:36 PM
Hey guys wats a good driver cleaner? Dashock Troubleshooting 2 September 11, 2008 07:30 PM
omega driver ebdoradz Video Cards 1 August 24, 2007 07:18 PM
