Originally Posted by draemn Yeah, I'm just curious because everyone uses such vastly different test benches. Some use the X58 platform and usually get around 3.8 Ghz, some use P55, and others use the P67... I also find that there is a huge difference in CPU speeds as there are clocks from 3.2 Ghz to 4.2 Ghz depending on the review.
Any thoughts on what CPU/clock speed is needed to remove a CPU bottle neck when you get into the high end SLI/CF realm? |
It depends on the game but 4 cores at 4.2 ghz should be fine for almost everything.
