  #21 (permalink)
Old March 22, 2011, 09:04 PM
I hope to God that my 6950 is one of the ones that works
  #22 (permalink)
Old March 23, 2011, 04:40 AM
just make sure that whatever brand you're buying, get the 2GB as 6970 comes only 2GB
  #23 (permalink)
Old March 23, 2011, 04:30 PM
Delavan's Avatar
alright,
I really like the Asus Directcu II GTX570 cards. Why? Well they have better components and are equiped with more power phases than the reference cards...also they draw a little less watts...every little bit is a gain I guess...
My Mobo is Asus P8P67 DELUXE...I would like to SLI two triple-slots 570 directcu II cards on this board...will it fit?
IT seems like it will...I put a gtx260 in the top slot and it SEEMS like the is still 2 slot spaces before the next PCI-E slot on the mobo...
Are the PCI slots in the way? (slot connectors being a little higher than PCI-E slot connectors)..
According to my guesstimate, there would be a full empty slot between the top card's fan shroud aND the lower card's backplate...
Can somebody confirm plz?
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
  #24 (permalink)
Old March 23, 2011, 07:25 PM
Socrates_Johnston's Avatar
Originally Posted by Soultribunal View Post
When 3 Builds in total do the Exact same thing on the exact same games. I highly doubt 5 cards failed all at once.
ALthough yes, I do understand what you are saying. However the visable stuttering you see is not a failing card. I've never seen a card fail like that before, and its more prevelant in certain games over others.
ST
which brand?
OC gtx 560 sli vs OC hd 6950 (with hd 6970 flash) cfx CTA Video Cards 8 January 27, 2011 04:54 PM
First time doing SLI, some questions Musabi Video Cards 5 April 21, 2010 12:46 PM
5870 Vapor-X, Dirt 2, Q6600, CFX vs Non-CFX zc1 Video Cards 2 March 20, 2010 08:41 PM
8800GT SLI questions Zelzubub Video Cards 3 March 9, 2009 08:14 AM
PSU for SLI Questions. Milt Power Supplies 9 July 2, 2008 03:20 PM
