<~----> 84C Full Load normal for 5770 Ref Cooler? - Hardware Canucks
Old March 12, 2011, 07:39 PM
Default 84C Full Load normal for 5770 Ref Cooler?
I burnt my damned finger!!!
Anyways I know what you are thinking, MSI afterburner. Last time I used that I remember It would boot up my PC and the fan would be on 100%! How do I fix it?
Also is that temp normal?
Old March 12, 2011, 08:20 PM
if its the crappier 'stock' cooler and the fan is not probably going too fast,yes its possible.
piccie and aida64 screenie would seriously help too :)
Old March 12, 2011, 09:16 PM
martin_metal_88's Avatar
If your airflow in the case is not optimal yes this can happen. It's a bit high but IMO nothing to stress with. You could try making your own fan profile to make it turn a bit faster if you can handle the noise.
Could we have system spec and card model please? Some screen shot might help as well as dan prescribe.
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old March 12, 2011, 11:40 PM
well, I have a haf 922, and my cable management is like 95% perfect.
I've had the card for like maybe 8 months.
Other thing is, CCC has a different temp reading than GPU-Z
It's been fine for 8 months, and I have a life time warrenty so I dont really care ahah.
BTW is the batmobile cooler ahah.
Old March 12, 2011, 11:46 PM
i fingered.
meh, close an eye on it
Old March 12, 2011, 11:48 PM
WAIT WAIT WAIT... Its actally 82C max at 23C ambient.
I remember hitting like 87C in furmark when it was 26 or 27C ambient temp last summer.
Its weird, so GPUZ says 82 FULL LOAD
BUT FurMark/CCC says 66 FULL LOAD
Old March 13, 2011, 12:03 AM
how about aida64? DO TRY IT!! :)
Old March 13, 2011, 10:05 AM
either way, 87 isn't dangerously bad really. not optimal, but not dangerous.
[FS] Sapphire ref 5870 /w Accelero Twin Turbo Pro cooler (or without) Aix Buy/Sell & Trade 9 August 22, 2010 12:36 PM
What are normal 5770 temps? NineLives Video Cards 11 August 6, 2010 09:56 PM
Q9550 + Hyper 212+ HSF = 76c full load... Too high? oblisk CPU's and Motherboards 11 October 29, 2009 10:18 PM
Q6600 24/7 Full Load on Air Dizz Overclocking, Tweaking and Benchmarking 19 September 2, 2008 04:44 PM
Full Load/Temperature Questions Boat Overclocking, Tweaking and Benchmarking 11 November 12, 2007 12:27 AM
