Old March 9, 2011, 04:39 PM
Trial Member
Default -Bent- ATI Radeon HD 5870 Bent card
Currently, I have a Sapphire HD 5870 which I bought about 1 year ago. From my recent observations I noticed that the card is bent at the end, where 2 6 pin power connectors are.
Does this affect the performance of the card and is this problem reversible?
Thanks
Old March 9, 2011, 05:18 PM
maverick_brent's Avatar
this shouldnt affect the performance, and my guess is that the card is best because of heat, do you have an aftermarket cooler on it? reason i ask that is two fold, if you have o'ced and didnt have an aftermarket cooler, you could have warped the card based on heat, or if you DID have a cooler on it that was heavier that the original weight could have been the culprit.Pictures would help us to identify a bit more.
Old March 9, 2011, 05:23 PM
JD JD is online now
Fair typical and shouldn't be of any harm.
My HD5870 is pretty bent too due to the weight of the waterblock I put on it. Not the best of pictures, but hopefully gives you something to compare to:
Been like that for just over a year now and the card still works fine.
Old March 9, 2011, 05:24 PM
Dr_BenD_over's Avatar
Fallen Folder
When I first saw this I actually went ahead and added some spacers for support
But I've had eight cards since and I haven't worried about it or had a card fail.
All's well that's Haswell
x58 Bent Pins: Updated. JORD4N CPU's and Motherboards 7 October 28, 2009 09:47 AM
OMG 2 Pins On The CPU Socket Are BENT ! JORD4N CPU's and Motherboards 23 October 20, 2009 05:57 AM
XFX ATI Radeon HD 5870, How Loud ? JORD4N Video Cards 2 October 13, 2009 07:24 AM
XFX ATI Radeon HD 5870 Video Card Unboxing FiXT Video Cards 33 September 27, 2009 10:11 AM
ATI Radeon HD 5870 Pictured and Detailed FiXT Press Releases & Tech News 75 September 14, 2009 10:08 PM
