Old March 8, 2011, 08:31 PM
CTA's Avatar
CTA CTA is offline
Default temp monitor for dual video cards
try to use cpuid hw monitor and it didnt tell temperature from two video cards... only one... and i think 32'c idling to 41'c loading is not right number... (watercooling)...
do you know which is most accurary reader for ati 6000x?
Old March 8, 2011, 08:34 PM
idk about this particular card but did you tried msi afterburner?
try aida64, theyll probably need an update though.
Old March 8, 2011, 08:40 PM
CTA's Avatar
CTA CTA is offline
i dont want to try them ;p (nor misread the temperature)
i need to know that program will read temperature of two video cards...
Old March 8, 2011, 08:45 PM
mchutch's Avatar
MSI Afterburner for sure, works great, use the settings to switch between the two cards..
Old March 8, 2011, 08:47 PM
msi AB does...what more can i say
ipaine's Avatar
Well I use AIDA64 and it can read temps from two different cards. I had it reading temps from both a 8800GT and 460 at the same time.
Also it will give me GPU Core and Vcc voltage, GPU temp, GPU ambient temp and GPU memory temp. Really it will give you as much info as the card can provide.
"Nothing sucks more than that moment during an argument when you realize you're wrong."
Old March 8, 2011, 08:49 PM
JD JD is offline
I'm surprised it hasn't been mentioned, but GPU-Z is great and entirely free.
Old March 8, 2011, 08:51 PM
CTA's Avatar
CTA CTA is offline
i tried and dont see setting but it already displays both temperatures...
again 40'c loading for gpu1 temperature seems not right... especially 36'c for gpu2... :?
jd, i know about gpu-z but i need close accuracy temperature monitor for hd 6x's...
Old March 8, 2011, 09:05 PM
mchutch's Avatar
Makes sense GPU 1 is a little hotter..
Asus ARES Video Cards - CrossFire [Video] AmuseMe Reviews & Articles from the Web 5 July 1, 2010 07:34 AM
Whats the best CPU temp monitor software? what do you guys use? mjpd1983 O/S's, Drivers & General Software 14 June 29, 2010 10:37 PM
Just installed new GTX 260, what program to control fan and monitor temp? The MAX Overclocking, Tweaking and Benchmarking 5 January 16, 2010 01:36 PM
Q about real temp by intel and CPUID monitor contractk Overclocking, Tweaking and Benchmarking 8 March 29, 2008 09:51 AM
What do your video cards temp while just playing singleplayer COD4..... ? Canadianguy Gaming 12 March 9, 2008 10:38 AM
