Old March 8, 2011, 09:13 PM
Arinoth's Avatar
Personally i prefer MSI Afterburner for both my amd and nvidia cards over anything else.
Here I am: here I remain
Old March 8, 2011, 09:16 PM
CTA's Avatar
CTA CTA is offline
Originally Posted by mchutch View Post
Makes sense GPU 1 is a little hotter..
is it because of cpu's average 55'c loading tempature? and reduce the temperature of gpu2 after cooler gpu2's 40'c loading tempature?
Old March 8, 2011, 09:59 PM
usually gpu1 is used more than gpu2
water temps is consistent throughout the loop, one component won't dramatically affect the others.
if both gpuz and msi ab shows that temp than it is what the sensor says....the temps reported are as accurate as the sensor is.
Old March 8, 2011, 10:24 PM
JD JD is offline
Those temperatures seem perfectly fine. My HD5870 does around the same. It's idling at 32C. Load is around 40-45C.
Water is an absolute god-send for GPUs I'd say. There simply isn't enough surface area/fan size to properly air cool a GPU when compared to the contraptions we attach to our CPUs.
Old March 9, 2011, 06:44 AM
Soultribunal's Avatar
GPU-z is very good, Everest is good as well.
But I prefer for ATI to use MSI afterburner, and nVidia I use precision.
Your first card being hotter makes sense as its the primary GPU (as was already mentioned).
And those temps seem fine to me.
ST
www.realhardwarereviews.com
Old March 9, 2011, 11:24 AM
CTA's Avatar
CTA CTA is offline
ok.. i will keep this information in my mind..
yeah, jd... just find hard to believe that 35-40'c for watercooling... compare to crappy aircooling... i dont think i will go back to aircooling again... ;p
Old March 9, 2011, 01:19 PM
Dr_BenD_over's Avatar
Fallen Folder
GPU-Z will monitor both. With 100% of both Sli and CF setups I've had, card 1 was always hotter, even if it had better cooling. I think you'll notice more of a difference between air and water cooling with a 100% load on the cards.
All's well that's Haswell
Asus ARES Video Cards - CrossFire [Video] AmuseMe Reviews & Articles from the Web 5 July 1, 2010 07:34 AM
Whats the best CPU temp monitor software? what do you guys use? mjpd1983 O/S's, Drivers & General Software 14 June 29, 2010 10:37 PM
Just installed new GTX 260, what program to control fan and monitor temp? The MAX Overclocking, Tweaking and Benchmarking 5 January 16, 2010 01:36 PM
Q about real temp by intel and CPUID monitor contractk Overclocking, Tweaking and Benchmarking 8 March 29, 2008 09:51 AM
What do your video cards temp while just playing singleplayer COD4..... ? Canadianguy Gaming 12 March 9, 2008 10:38 AM
