Originally Posted by SugarJ Huh? In SKYMTL's testing, not once did it beat 2x 6970 CF'ed at ANY resolution. And I trust his a lot more than anyone else's. If you're going that far afield to try to find something to prove your point, maybe you should consider spending your efforts elsewhere. |
That comment just sounds disrespectful, and I really don't appreciate it. WGSF is probably at the forefront of multi-monitor gaming, with more experience and expertise than Anyone. And my point wasn't really the difference in frames, but that a 6990 does it in one card... with an option to add a second. With a 6970 Xfire setup you'd be hard pressed to get a quad fire board that will perform, not overheat, and still beat a far simpler 2-card 6990 setup.
Again though, these hypothetical situations are for extreme enthusiasts only. But my point is that the 6990 may be an option for them, over a trifire/quadfire 6970/6950 setup.
