Old March 3, 2011, 08:16 AM
Default Some questions
Hi there,
I have some questions about video cards
1) Are there going to be Sapphire AMD Radeon HD 69xx Vapor-X cards?
2)What's the best cooler? Vapor-X, Direct CU II, Twin Frozr?
Just curious. The 6990 probably gonna cost around 600-700 euro right??
Old March 3, 2011, 08:44 AM
1) probably?
2) the best cooler is subjective really, I mean they all cool relatively well. Noise is a factor as well with cooling you have to remember. If you're not picky, I wouldn't be picky, they're all going to perform well.
pricing for the $6990 is likely is the area of $550 usd. +- $50. - 450 euros? I'm not sure how computer part prices are over there.
Old March 3, 2011, 09:58 AM
JD JD is offline
I don't believe all OEMs are picking up the HD6990, as such the only "custom" card I'd expect to see is from ASUS in the form of ROG which will cost an insane amount if they do it.
Old March 3, 2011, 12:36 PM
Delavan's Avatar
I can't talk for the HD69** series, but LINUS tested the the GTX560TI in DirectCU II and twin frozr II iterations...
The twin frozr II is both QUIETER and COOLER...
Twin Frozr II & DirectCUII Cooler Comparison GeForce GTX 560 Ti Linus Tech Tips - Linus Tech Tips Blog
i7 4770K @ 4.0GHz / Corsair H100i / MSI Z97A Gaming 6 / 16GB Kingston Hyper X 1.5V 1600 / MSI GTX1070 FE / Samsung 850 Evo 500gb / Corsair Performance Pro 128GB SSD / Intel 520 120GB SSD / WD Black 640 GB storage / XFX 850 watts Black Edition PSU
Old March 3, 2011, 03:54 PM
sa seba's Avatar
I would buy a xfx 6999 and slap a Accelero XTREME Plus on it.
Old March 3, 2011, 04:20 PM
No, 6990 is not compatible with it. It only has like 1 GPU thing on the bottom and they say it only is for blablabla.. Or 6999? What's that. And how do you put it on it. I'm not so pro.
Old March 4, 2011, 04:18 PM
sa seba's Avatar
Silly me, I was dreaming again. But just wait a bit and arctic cooling will release a product for that and it will be amazing!
A few questions Spiros CPU's and Motherboards 7 November 7, 2009 02:49 PM
:New: Questions. crazyhorsejohnny HardwareCanucks F@H Team 28 August 25, 2009 02:06 PM
questions. BrainEater HardwareCanucks F@H Team 15 December 5, 2008 09:53 PM
Few questions AnthraxAdrian CPU's and Motherboards 2 April 13, 2008 07:08 PM
Some questions about F@H qwerty HardwareCanucks F@H Team 4 October 16, 2007 06:45 PM
