Old March 2, 2011, 11:11 AM
Is 3dMark11 worth the $20? If you guys say so, I'll buy one. I'd like to test out my new Zotac 560ti
Desktop: Asus Maximus V Gene | 3570K @ 4.2Ghz | 4x4GB G.Skill DDR3-1600 16GBXL 9-9-9-24 | Patriot PYRO SE 240GB SSD | Gigabyte 650ti Boost | Seasonic X-460FL 80PLUS Gold Modular Fanless Power Supply
http://feedback.ebay.ca/ws/eBayISAPI...onthelam7&iid=
http://heatware.com/eval.php?id=44147
Old March 2, 2011, 01:19 PM
Cowboy's Avatar
I got P3810.... what does it mean?
Old March 2, 2011, 01:22 PM
Arinoth's Avatar
your overall score is irrelevant as your cpu is dragging your score down. Link your results page or let us know what the GPU tests reported (and GPU score)
Here I am: here I remain
Old March 2, 2011, 01:25 PM
Cowboy's Avatar
Result
Old March 2, 2011, 01:27 PM
mchutch's Avatar
That score says your setup is running well, you may be able OC and get a tad more but be careful with temps, 3Dmark11 is really pushing your 560 full out.
I'm interested in seeing everyones' scores, just went SLi with two Zotac GTX 560 Ti OC, and have a huge resolution (6040x1080) so would definitely would like to see your score Arinoth..
Old March 2, 2011, 01:29 PM
Arinoth's Avatar
Don't want to thread jack, my stock and overclocked results are over in the 3dmark11 page in benchmarking.
Old March 2, 2011, 02:42 PM
FiXT's Avatar
Hall of Fame
Use the Futuremark result tool: Search
Use that, put in your system specs, and you can find out where your system "should" fall.
Obviously keep in mind there will be variances for overclocking, systems running, etc.
Old March 5, 2011, 03:05 AM
Just for the helluvit, I ran 3d 6 on my GTX275 and got 20994. EVGA560Ti gave me 24729 on same. I'm waiting for my code from evga for 3d 11.
3DMark 11 is online! Post you scores! Delavan Overclocking, Tweaking and Benchmarking 283 November 7, 2017 03:12 PM
3DMark 06 & Vantage scores Jonwall Overclocking, Tweaking and Benchmarking 206 March 25, 2015 10:19 PM
560Ti SLI benchies... Delavan Video Cards 7 February 3, 2011 04:08 AM
Team Fortress 2 Scores!!! Airshehan Gaming 9 August 4, 2009 09:26 AM
Curious about Vantage scores kragnorok Overclocking, Tweaking and Benchmarking 10 May 17, 2009 11:59 AM
