Old February 26, 2011, 07:46 AM
Default Could this be why my crossfire setup has problems?
Hey guys,
I recently opened up my 5850 cards to replace the thermal paste inside and not to go off topic but my god do they ever use crap TIM for their GPUs.
Anyhoo, I took some pics of the GPUs and noticed some differences in the numbers on the chips themselves. Could this be why I get so many issues with BC2 and other games? I mean, it's not like I'm running a dinosaur of a system. Everything is up to date and working fine.
Check out the pics and let me know what y'all think
cheers and thanks
Old February 26, 2011, 08:06 AM
It honestly looks like your running 2 completely different cards.
Old February 26, 2011, 08:10 AM
Are you just saying that because the boards are different colors??
sswilson's Avatar
Wouldn't the last number be the actual GPU P/N while the other numbers are either lot numbers and/or manu plant?
If so, it looks like the two numbers match up. What does GPU-Z give you for information on the two cards?
Old February 26, 2011, 08:11 AM
Arinoth's Avatar
Have you tried updating your bios and made sure when you run crossfire the bridge is installed and its enabled in catalyst
Here I am: here I remain
Old February 26, 2011, 08:18 AM
come on man.... I"m not that stupid!!!
CF was enabled but since I play BF2 I've had to disable it to get decent performance at high settings.
Old February 26, 2011, 08:22 AM
" What does GPU-Z give you for information on the two cards?"
For the most part, they seem identical.
Old February 26, 2011, 08:23 AM
Arinoth's Avatar
Sometimes its the simple things we overlook. There was someone in the past whom forgot to put in the second PCI-E power connector into one of their cards. Its easier to rule out the stupid things then realize them down the line.
I'm not sure if this is true for all cards, however have you set both cards to the same speeds?
Old February 26, 2011, 08:27 AM
I understand.... CF had to be disabled to get decent performance in BC2. all bridges are on and oriented in the same direction. Tried one bridge in different slots and tried both bridges... Nothing seems to make a difference.
Old February 26, 2011, 08:57 AM
Coach's Avatar
What are the rest of your specs?
EDIT: NVM I see them there
Major Crossfire Problems! HD5850 Libertad Video Cards 5 January 6, 2011 01:44 PM
Crossfire Setup grifter11 Video Cards 9 November 16, 2010 01:01 PM
Crossfire Multi-monitor setup? nzorov Video Cards 4 April 16, 2010 08:33 AM
Crossfire setup with random shutdowns NightRain Troubleshooting 4 June 22, 2009 11:27 AM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
