Hello.
I wish to connect my HD6850 Graphics card to my old 21.5" TV. The TV has analog TV aerial plug and 3 pin RCA connectors.
I wish to have both the Audio and Video from the TV. So what do I need to accomplish it? I think only HDMI is able to carry both audio-video signals. So will a cable with HDMI on one end and 3-pin RCA on the other end will give me Audio-Video from my TV? If not, then what else would I need?
Also, my card's one DVI is used by my PC monitor, so will it be able to use another port for connection? I have heard that some cards are incapable of using both DVI or one DVI and one HDMI at the same time?
My Specs:
CPU: AMD Phenom II X2 555 Black Edition
Link Motherboard: ASRock M3A785GXH
Link GPU: ASUS 1GB 256-bit Radeon HD 6850 DirectCU
Link RAM: Kingston HyperX 4GB (2 x 2GB) DDR3
Link
Thank you for your help.
