Old January 16, 2008, 01:25 PM
Default Budget video card advice needed please.
I am attempting to put a budget system together for my brother. I have some older components from previous builds but need some advice on a budget video card. The build will consist of an amd X2 3800+ (939) and 2g pc3200 ram. I had planned on buying the XFX 7900GS ($116.99) from DC but they are sold out and I was informed that the card is discontinued. I figured it was the best bang for the buck, beating out the newer 8600GT. This system will be pretty much used for playing World of Warcraft and possibly Call of Duty 4.
Should I just snag a 8600GT? Any advice on a video card in the $100 - $140 area would be greatly appreciated.
Mumbly
Old January 16, 2008, 01:28 PM
donimo's Avatar
ati 3850, waaaaaay better than an 8600 (any model), 190bux but it is 100x better than anything under 200...
Mobo GA-Z77X-UD3 CPU i5-3570K stock RAM:2x4GB Patriot Viper 1866 1.5v GPU:XFX HD6850 BE + Gigabyte HD6850 @820/4400MHz Case:Bitfenix Raider w/2x 200mm + 135mm PSU: Corsair HX620
Old January 16, 2008, 01:50 PM
DaBruuzer's Avatar
I have to second the 3850 in this case. Although not traditionally an ATI fan myself, that card easily out-performs anything under $200 right now. They can be found around the $170-200 range. There is one available from Direct Canada for ~$172 with $9.99 Air Shipping right now:
Diamond Viper Radeon HD 3850 256MB GDDR3 PCI-E Dual DVI-I HDCP HDMI HDTV Out Video Card - DirectCanada
Intel Core 2 Quad Q6700 @ 3.2GHz
Gigabyte GA-P35C-DS3R
OCZ Vendetta CPU Cooler
OCZ Reaper HPC 4GB (2x2GB) DDR2-800
XFX GeForece 8800GTS 512 (G92)
WD SE16 500GB SATAII / WD 250GB SATAII
LG SATA DVD-RW
Corsair HX520 Modular PSU
Antec P182 w/all fans replaced w/Noctua NF-P12-1300s
BenQ T221W 22" LCD @ 1680x1050
Logitech X-540 5.1 speakers
Vista Ultimate 64-bit
Old January 16, 2008, 01:55 PM
belgolas's Avatar
If you can go for the 3850 then go for it.
http://www.ncix.com/products/index.p...acture=Diamond $189.99
http://www.ncix.com/products/index.p...facture=NCIXPC $179.99
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old January 16, 2008, 02:01 PM
sswilson's Avatar
Heh.....
Or since you're local to me, you can ask me via PM about the used 1950pro I'll have up for sale once my new vid card comes in........ :)
Old January 16, 2008, 05:10 PM
werty316's Avatar
You can't go wrong with a HD3850.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old January 16, 2008, 09:56 PM
Amon's Avatar
The 8600 GT is good. Performs very well for under $100.
But I'd also point you in the direction of a Radeon HD 3850.
Old January 16, 2008, 10:33 PM
Ugly n Grey's Avatar
If the suggestions for the stretch from your budget to the price of the recommended 3850 is too much, you can get very good deals on 1950 series based cards as sswilson pointed out. I'd tend to go that route, I've also seen some good prices on used Nvidia cards. with their longer warranties the used Nvidia cards tend to be better deals to buy used.
Old January 17, 2008, 12:56 AM
Thanks for all the responses guys. It is greatly appreciated. I had thought of the 3850 but being this close to Xmas passing it just isn't in the budget. My thinking is that an 8600GT would do him fine but wanted some thoughts from you guys.
I will take a look and see if I can find an 8600GT with 512mb. I will also send SSWilson a pm and ask what he would sell his 1950pro for. Thank again for all the imput. Just trying to put a good comp together for my brother.
Mumbly
Old January 17, 2008, 05:59 AM
belgolas's Avatar
195- pro is a good card too.
Sponsor a child!
Fight poverty.
Qoute by Perineum
Need advice picking a video card tgraszat14 Video Cards 16 February 1, 2008 10:00 PM
Advice on mobo needed badly 999Virus999 CPU's and Motherboards 8 January 11, 2008 11:23 PM
What kind of video card is needed for this LCD TV neurobashing Display Units 1 August 13, 2007 02:02 PM
What kind of video card is needed for this LCD TV neurobashing Video Cards 3 August 10, 2007 02:56 PM
Budget Video Card Selection BALISTX Video Cards 14 June 17, 2007 09:24 AM
