Originally Posted by EdHilario If it's raw FPS power then the 5850 still had the edge over the 68xx series and the 5870 would definitely be better than the 6850. It was meant to replace the 5830.
Think more about the 6950 if you are going to go over to the 6xxx series cards. |
Well if you read the reviews here in actual (not sythetic benchmarks) the 6870 edges ahead of the 5850. I myself was persuaded by the team here to opt for 6XXX series card vs cheaper 5850's.
I don't regret it one bit.
ST
