Old February 19, 2011, 01:54 AM
Default XFX Radeon HD 5670 HD567XZNF3 uses a reference design?
Graphic Cards - ATI Radeon HD 5000 - ATI Radeon
Does anyone here know if this card uses a reference design? I need to know so that I can go and get the appropriate aftermarket heatsink to silence this card. This is also the cheapest card that I can find, which supports Eyefinity. I don't intend to do any gaming, but rather just power three Dell U2211Hs for work. If anyone know of any other cheap Radeon card which supports Eyefinity and uses a reference design, then please let me know if this one doesn't fit the bill.
Old February 19, 2011, 07:23 AM
I don`t know but if you are just working powering 3 monitors it really shouldn`t be all that loud. Also you can just buy a noise reduction kit that should be cheaper than aftermarket cooling (which isn`t always all that quiet).
Old February 19, 2011, 07:26 AM
Delavan's Avatar
This little card is decent. I bought one for my dad's rig.
He's got a i5 760 stock and this card and 3Dmarks06 gives a 11 000 pts score...the sound wasn't bad AFAIK...
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old February 19, 2011, 08:45 AM
I don't think it'll be that expensive to slap a passive heatsink on it if this card uses a reference design.
Old February 19, 2011, 10:24 AM
if you don;t already have the card you can pick up this
Newegg.ca - SAPPHIRE Ultimate 100289UL Radeon HD 5670 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity... if you do already have it you can sell your old one and pick up this one.
HD 4890 Reference Design Keltron 3030 Video Cards 6 August 12, 2010 03:49 PM
How to tell which card is reference design? Pelt Video Cards 9 May 17, 2010 06:42 PM
Will the XFX HD 5870 Reference Design OverVolt? Kommandant986 Overclocking, Tweaking and Benchmarking 4 May 3, 2010 03:54 PM
PowerColor Launches Overclocked Radeon HD 5670 PCS+ FiXT Press Releases & Tech News 1 February 2, 2010 10:59 AM
AMD Launches ATI Radeon HD 5670 Graphics Card FiXT Press Releases & Tech News 0 January 14, 2010 09:58 AM
