Old February 16, 2011, 05:30 PM
Default Trying to do Eyefinity on 6950
I have 3 LG monitors and an HIS 6950 2GB. 2 running on DVI, and one still not hooked up. I already have an active displayport to dvi adapter. The problem is, my 6950 has MINI displayport outputs.
So I went on monoprice and bought a simple 6 dollar minidisplay port to displayport adapter. I just received the adapter and hooked everything up.
6950 > minidisplayport to displayport > active displayport to dvi > lg monitor
It doesn't work. It doesn't get recognized at all. I've tried using the adapters on all three of my monitors, but still no go. So do I HAVE to have an active mini display port to dvi adapter for this to work? Or do you think one of my 2 adapters are defective?
Old February 16, 2011, 07:58 PM
Most mini DP to DVI have a USB hookup and a the mini DP... This means that you need to go directly from mini DP to DVI. The adapter should look something like the one here.
6950 mini display port - Overclockers UK Forums
actually after further review newer ones don't need it... make sure your adapters are the right ones (mini DP 1.1 vs 1.0 etc).
6950 size techman95 Video Cards 14 February 2, 2011 12:56 PM
which 6950? techman95 Video Cards 6 January 29, 2011 04:07 PM
6950 can still be had for ~$267 Coach Video Cards 41 January 8, 2011 05:39 PM
6950 dilemma Coach Video Cards 2 January 5, 2011 01:32 PM
