Old February 7, 2011, 02:37 PM
Default Bottlenecking
So I didn't know whether to put this in here or in CPU section but what is the best grafics card i can get that a core i3 530 at 4ghz wont bottleneck.
Old February 7, 2011, 02:50 PM
maverick_brent's Avatar
Whats your budget...single card or sli/crossfire? My vote goes to 6950 regardless...unless your budget is lower
Old February 7, 2011, 03:25 PM
what resolution/eye candy do you run your games at?
the above card is quite good in its price range for higher resolutions.
Old February 7, 2011, 05:38 PM
The resolution is to be decided i definately won't be going too crazy though. My budget is somewhat hazy at this point but i think with the new build I am looking at i might be able to pull $250 off. I see a 6950 for $260 and I'm definately going single card. Also will a 6950 fit in Buy the Ultra Gladiator Mid-Tower ATX Case at TigerDirect.ca
Old February 7, 2011, 05:44 PM
at that budget you dont need to worry about any sort of bottleneck.
it should fit in that midtower, yes. If it's an easy fit.. well..
Old February 7, 2011, 06:38 PM
Okay so I have just decided I'm going to try to aim for below $200, that way I can also put in a nice shiny SSD sooner. How does the GTX 460 1gb sound? From what I have found for $150 it seems to be the best.
I'm only going to be using one monitor so my resolutions wont be huge but I'd like them to be good.
Old February 8, 2011, 12:01 AM
150 is a good price, go for it!
Am i bottlenecking my 5870? mjpd1983 New Builds 17 June 16, 2010 07:53 PM
what is bottlenecking my card? lexmark1 Video Cards 12 July 24, 2009 09:39 AM
Signs of bottlenecking? C_O_N Video Cards 16 May 3, 2009 06:59 PM
BottleNecking? Chromey Video Cards 10 April 6, 2009 05:36 PM
What do you suppose is bottlenecking this PC? LookAQuesadilla Troubleshooting 14 April 30, 2007 09:16 AM
