-   -   upgrade advice 1680x1050 (http://www.hardwarecanucks.com/forum/video-cards/40565-upgrade-advice-1680x1050.html)
ccm001 February 6, 2011 02:07 PM
I'm thinking about upgrading my vid card and am looking for advice.
I currently have a gtx260 896meg core 216 card, and I use a 22" monitor that supports max 1680x1050 resolution.
Given my resolution limit (I don't plan on upgrading my monitor) what would be a good card to go with in the sub $200 range? I was thinking about a 1g 6850 (my motherboard supports crossfire, so it could be an option in the future) or a gtx460.
Would I be okay with a 768m gtx460 at my resolution, or spend the extra and get a 1g. If there wouln't be much difference between a 768 and a 1g at my resolution I coudl save myself lots of money ;). I was thinking about the 6850 since my motherboad is amd, and my processor is amd - I might as well complete the "amd fusion". And it looks as if the gtx460 and the 6850 exchange blows in gaming performance at lower resolutions.
Any advice appreciated as always :)
_dangtx_ February 6, 2011 02:23 PM
6850 all the way, unless the 460 can be found cheaper.
try to go for the 1gig version if pocket permits.
ASUS GeForce GT 440 1 GB Review - Page 26/30 | techPowerUp
look up the numbers +
http://www.hardwarecanucks.com/forum...-ti-220-a.html
JD February 6, 2011 02:40 PM
Are you having issues with certain games? I'd think the GTX260 could still hold up with 1680x1050...
yamawho February 6, 2011 03:02 PM
I upgraded one system from a GTX 260 to GTX 460 768MB.
The difference in the FarCry 2 benchmark is 20% increase in FPS looking at the average score.
I don't know what the rest of your system has but I for example swapped out a HD 4870 with the GTX 460.
I was shocked to discover there was a small increase only ... almost the same :shok:
That system has a E8500 ... when I installed the same card in a AMD x4 965 system it was 45% faster using the same benchmark at 1680 x 1050.
I oced the E8500 o 3.8 Ghz and the difference now is 25% less than the AMD x4 965 system ...
Hope this helps.
gingerbee February 6, 2011 03:14 PM
at that res i dont think you'll see much of a differance the gtx 460 does fine even at 1080p so that low should not matter
ccm001 February 6, 2011 03:21 PM
It looks like the 460 is slightly better than the 6850. Both are about the same price right now.
Not really. I just want to be able to take advantage of tesselation and other eye candy, while also increasing fps. Mainly I'd like to sell the 260 while I can still get some half-decent cash.
@yamawho: I run an amd 965be, so I'd love to see a %45 improvement ;)
So either way, 6850 or gtx460, I'd see an improvement in eye candy and fps over a 260 (I hope)?
ilya February 6, 2011 03:38 PM
At your current res, you'd probably see more benefit from overclocking. But if you're lucky and manage to sell your 260 for a really good price, ($90+) you may as well go for a cheap 460 768mb. ~$50 for a video card upgrade isn't bad.
yamawho February 6, 2011 03:52 PM
Hehe the 45% was compared to the E8500 system.
The increase is about 30% using the FarCry2 benchmark...
Got his one ...
NCIX.com - Buy MSI GeForce GTX 460 Fermi Cyclone OC 725MHZ 768MB GDDR5 Dual DVI Mini-HDMI DX11 PCI-E Video Card - N460GTX Cyclone768D5/OC In Canada.
ZZLEE February 6, 2011 04:59 PM
Newegg.ca - EVGA 01G-P3-1373-AR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Egg Daly deal 214 $ + 30$ mra
yamawho February 6, 2011 05:07 PM
I Used MSI afterburner to overclock mine up to 810 Mhz on the core and got a blistering 3 FPS increase :blarg:
Overclocking the video card is overrated ...
