  #21 (permalink)
Old February 7, 2011, 07:44 AM
gingerbee's Avatar
nothing against sapphire but the only cards i have had die early deaths on me in the last 5 years were saphire cards. And i am a big fan of xfx so my choice would be clear here good luck on your buy.
  #22 (permalink)
Old February 7, 2011, 10:33 AM
GT7R's Avatar
I'd say stretch a bit, you can't go wrong with a 560Ti or a 6950 1G.
Worth it.
  #23 (permalink)
Old February 12, 2011, 09:03 PM
Decided to go ahead with this:
Newegg.ca - ASUS EAH6850 DC/2DIS/1GD5/V2 Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Read many reviews, the Asus overclocks well and tests to have the lowest noise levels, temperatures , and power consumption - even when overclocked.
Should be here by the end of the week
After a few months (maybe tax return season) I'll get another for crossfiring
Thanks to everyone in this topic
Advice on new build/upgrade KonstigtSjael New Builds 4 February 1, 2011 02:30 AM
Upgrade Advice Needed wedge22 CPU's and Motherboards 4 May 4, 2010 08:07 PM
Advice on NEW Build upgrade?? Surk New Builds 17 December 8, 2009 11:06 AM
Looking for advice on RAM upgrade Arundor RAM 4 November 22, 2008 06:21 PM
Advice on Ram upgrade Sniper RAM 8 October 25, 2008 10:28 AM
