Old February 6, 2011, 06:42 PM
Originally Posted by ilya View Post
But if you're lucky and manage to sell your 260 for a really good price, ($90+) you may as well go for a cheap 460 768mb. ~$50 for a video card upgrade isn't bad.
I had someone offer $80 for it. So it would be about a $50 upgrade if you count rebates.
With shipping and factoring in rebates, a 1g 6850 would be $25 more than a 1g gtx460. So pretty much the same price. That's not making it easy to decide
Basically I think I have to decide if I'm ever going to buy another 6850 and crossfire at some point. Or will I want to upgrade to a newer card. If I'm going to just keep upgrading to new cards then I'd buy the 460 now. I'm not a "hard core" gamer, so I wonder if I'd even ever bother with crossfire other than to just try it.
Old February 6, 2011, 07:22 PM
if youre going to spend 216 for a 460, why not 220 for the 560? :)
Old February 6, 2011, 07:36 PM
I agree with Dangtx here...the 560's at $220 is a much more significant upgrade than $200-210 for a GTX 460.
Old February 6, 2011, 07:56 PM
its hard these days lol...let me try again
http://www.hardwarecanucks.com/forum...-ti-220-a.html
ASUS ENGTX560 TI DCII/2DI/1GD5
oops,too bad, out of sale. gl man :)
Old February 6, 2011, 08:40 PM
I do appreciate all the input guys, keep it coming
Here's the dollars and cents of it; final cost to me factoring in sale of my 260 and rebates
gtx460 768m about $42 (asus, stock speeds, 3 year warranty) or $53 (evga, superclocked, lifetime warranty)
gtx460 1g about $71 (stock speeds)
6850 1g about $76
560ti 1g about $168.
When I calculated earlier that the 460 was $25 cheaper, it was with an SE version, my bad.
So the 560ti would cost me about $100 more. I don't think it would be cost effective performance wise at my resolution.
So definitely a cheap upgrade with a 768m gtx460, could get a year out of it. Would it be worth the extra $20 or so for a 1g 460 or a 6850 at my resolution? Possible future crossfire with the 6850.
Old February 6, 2011, 08:43 PM
JD JD is offline
dan, why do you keep referencing the GT440? Might be a bit confusing to the OP...
I still don't think there's much point in upgrading right now, especially since games that use DX11/tessellation are pretty slim...but if you must, I'd wait for a good sale on either a GTX460 or HD6850.
If you don't mind buying used, maybe checkout our BST area. I see there's some GTX460s for about $150 or so.
Old February 6, 2011, 08:49 PM
On the low end 6870 on the upper 560 or the 570 but I wouldn't bother with gtx460 192bit over the gtx260 you already have, not enough jump.
Gaming FX 8350 stock / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.6GHZ/GA 970 Gaming/ R7 265 1GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old February 6, 2011, 08:53 PM
No confusion, I see the article uses the gt440 as the reference in those charts, so the improvement percentage is relative to the gt440.
Tee hee, that's why I'm itching, there is some pretty good sales on right now
Although if I wait a little bit, they might drop a little more.
I can buy new gtx460's for about $150 right now (although after rebates, but still worth the chance IMO since it would be under warranty)
  #19 (permalink)
Old February 6, 2011, 09:24 PM
its the latest chart they got, nothing to do with the lowly lowly lowly puny 440 :)
i still think 6850.
better power figures, you can give it a clocking..and use your 260 for physx :p
  #20 (permalink)
Old February 7, 2011, 06:47 AM
I'll be selling that 260 to help pay for the new card ;)
I might give the 6850 a try. I've been an nvidia user for my last 2 cards, but I'll give a radeon a try.
Now should I get an xfx with double lifetime warranty, or buy a saphire.
Always a decision
Advice on new build/upgrade KonstigtSjael New Builds 4 February 1, 2011 02:30 AM
Upgrade Advice Needed wedge22 CPU's and Motherboards 4 May 4, 2010 08:07 PM
Advice on NEW Build upgrade?? Surk New Builds 17 December 8, 2009 11:06 AM
Looking for advice on RAM upgrade Arundor RAM 4 November 22, 2008 06:21 PM
Advice on Ram upgrade Sniper RAM 8 October 25, 2008 10:28 AM
