-   -   Anyone running HD6950/6970 crossfire? (http://www.hardwarecanucks.com/forum/video-cards/40537-anyone-running-hd6950-6970-crossfire.html)
lowfat February 5, 2011 02:03 PM
I am having an issue w/ my HD6950 crossfire where GPU2 always runs @ 100% usage even in the desktop. I've tried the Cat 10.12s and the 11.1s. Both w/ the same result. I have no overclocking software installed. I've tried installing just the display drivers. Everything always results in it running 100% utilization.
Eluder February 5, 2011 05:21 PM
Do you have dual monitors?
JD February 5, 2011 05:34 PM
I believe Arinoth had this issue with his Crossfire 6870s which is why he moved to 560s.
lowfat February 5, 2011 06:11 PM
Nope. Just one.,
I've been told the 10.12a drivers might work. Too busy overclocking the 2600k to try it out though. :biggrin:
Chilly February 5, 2011 06:24 PM
no issue here CF 6970, cat 10.12a
_dangtx_ February 5, 2011 06:48 PM
i take it uncrossfired both downclock properly? :)
lowfat February 5, 2011 06:54 PM
If I take a card out of the system and run them individually the GPU usage drops back down to 0%. And each of them work properly. However just disabling Crossfire in CCC does not work.
_dangtx_ February 5, 2011 07:09 PM
k, might be shooting blind here, but is it always gpu2? i mean if you switch cards around, disabled or not xf, its still goes full bore no?
im not telling you to do it, but i jump the gun and work the bios myself when i see the drivers are of no help.
lowfat February 5, 2011 07:22 PM
Yes I've swapped them around and it is always GPU2.
HiTi February 5, 2011 08:04 PM
Did you apply that registry fix or more of a work around for xfire. Apparently, its something to do with power (ULPS) management. I dunno if that helps or will work at all...just throwing it out there.
After reading about that issue again...i doubt that would help.
