Old February 3, 2011, 09:59 AM
Slik's Avatar
Originally Posted by Soultribunal View Post
Same difference. If its Nvidia reference design, it doesn't matter what vendor you choose.
PS- I edited my post above, I am going to say you can run them in slot 1 and 3 and it would be no different than 1 and 2.
ST
OK I will try that. They did not send me a longer bridge so I have no option other than to use the bridge I have for the 480s. Should I worry? I don't want to fry any thing especially after the tech guy told me not to do that. Problem with Dell tech is that you never know what country you will be routed to for service. Some speak a bit of English and some simply don't. Oh well...
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old February 3, 2011, 11:09 AM
Soultribunal's Avatar
Well there is nothing to my knowledge that says they changed the Bridge requirements from the 4XX series to the 5XX series so I am sure you should be okay. Again go with the rule of thumb, if it doesn't fit , don't force it :)
ST
www.realhardwarereviews.com
Old February 3, 2011, 11:30 AM
Slik's Avatar
ST
The older bridge fit perfectly on the first 580s delivered so I'm sure you are correct. As you know I have a VERY heavy rig to get at, so it will take a bit to get the new cards installed. Thank you very much for responding and your advice. I'm going to make myself a coffee,stare at this beast for a bit and then get at it. I will of course,report back the result.
[WTB] LGA775 mobo with 2 PCI-e slots ADay2Long Buy/Sell & Trade 0 November 9, 2010 09:28 AM
PCI Slots don't work? JD Troubleshooting 7 December 12, 2009 10:24 PM
Swaping pci-e raid card slots HaDeS Storage 2 November 26, 2009 02:17 PM
[WTB] Motherboard with 2 pci-e 16x slots Phobia Buy/Sell & Trade 7 April 29, 2009 09:24 PM
P5Q Pro Question - PCI-E slots anthonee1230 CPU's and Motherboards 11 March 16, 2009 02:30 PM
