Old February 1, 2011, 07:21 PM
techman95's Avatar
Default 6950 size
i posted a different thread about the two different 6950's a few days ago but came up with a new question...size. i have a cm storm scout case and im worried that the reference version wont fit in it. so if any one knows if it will or not i would be great full to know.
Old February 1, 2011, 07:26 PM
Soultribunal's Avatar
It should 'just' fit. The 6950 referance edition was just about as big as my MAtrix 260. And that one was a bit of a squeeze in my Scout.
ST
Old February 1, 2011, 08:13 PM
Scout - Cooler Master
CM Storm Scout Manual - Cooler Master
my bad, manual is crappy and website doesnt say..
reviews...
[Review] Cooler Master CM Scout - Overclock.net - Overclocking.net
The case was slightly cramped when all was said and done but everything fit well enough. I would be wary though if you have an overly large video card. My 9800gtx barely fit into the case... and I mean BARELY. Anything larger than the 9800gtx might not fit.
Cooler Master Storm Scout Review » Page 5 - Testing - Overclockers Club
Testing Setup:
Cooler Master Storm Scout Mid-Tower Case Review
Old February 1, 2011, 08:39 PM
Its approx 0.7inches bigger than my 260 was in the Scout.
I am going to say, from what I've read thus far you might not get it in there. They call for 270mm max in there (my 260 was 267mm) and the XFX 6950 is 287mm. So I'm going to say you might need to consider another case.
I could be wrong, so please someone correct me if I am.
That being said, I know the 6950 fits in my TT Armor A90, so You could always get one of those. They are fairly cheap.
ST
Old February 1, 2011, 08:48 PM
or look towards the haf series, 912? you can remove the hdd cage so it fits anything :)
its either going to be metal on metal close or not gonna fit. as per above.
what gets to me is cm not putting it on there website in plain view, like silverstone
for exemple : SilverStone Technology Co., Ltd - Designing Inspiration
Expansion Card 12.3"
HAF 912 - Cooler Master
Old February 2, 2011, 03:58 AM
Yeah but with that case Dan you have to remove the whole HDD cage so it fits. At least with the Armor A90 you can leave your whole cage in.
Just a Thought,
ST
Old February 2, 2011, 09:20 AM
techman95's Avatar
well i was wondering maybe taking some heavy duty wire cutters and going to town on the hdd bay and 5 1/2 bay to get it in there.
Old February 2, 2011, 09:29 AM
You're gonna have no choice if you want to use the case and card together I'm afraid. Or sell off the case and get the A90 :)
ST
Old February 2, 2011, 09:40 AM
techman95's Avatar
will the 1GB version fit with out any problems b/c i was also looking at at the xfx non-reference 1GB card
Old February 2, 2011, 09:44 AM
Just a Thought,
ST
you still have the secondary hdd cage on the bottom right there,
so unless you have 50 drives you're allright :)
i take em out asap even though its not needed. gives me more space
or elbow room :D
which 6950? techman95 Video Cards 6 January 29, 2011 03:07 PM
6950 can still be had for ~$267 Phill Video Cards 41 January 8, 2011 04:39 PM
6950 dilemma Phill Video Cards 2 January 5, 2011 12:32 PM
AMD HD 6950 FPS Luay79 Video Cards 4 December 14, 2010 06:42 PM
