Old February 1, 2011, 01:56 PM
Default overclocking evga 580 need help..?
hey everyone i just installed an evga 580 oc edition card but i was going to ask can i still overclock it more?
when i open msi afterburner here is what its at
core clock 797mhz
shader clock 1594mhz
memory clock 2025mhz (note if i try to change memory clock it will go back to 2025mhz
so i guess the only two i can change are the core and shader clock....but what should i change it to..pls any help would be great.
Old February 1, 2011, 02:55 PM
You change Core and Memory Clock and hit apply.
With the default 1.088 voltages on the OC edition... you can probably hit 850 core and 2100 memory for starters.
You can push it further if you unlock the voltages on msi afterburner.
Old February 1, 2011, 09:22 PM
rjbarker's Avatar
Yep....i can hit 900 / 2125 on all 3 OC Cards....any higher requires Voltage adjustments.
Classified SLi "Procyon II"
http://i30.photobucket.com/albums/c3...psafdd5ead.jpg
http://i30.photobucket.com/albums/c3...ps14a68ad9.jpg
3DMK 11
http://i30.photobucket.com/albums/c3...pse3993acf.jpg
Valley
http://i30.photobucket.com/albums/c3...psc01f1ceb.png
The Unofficial 580 waiting room (eVGA Step-up) ToXic Video Cards 39 March 11, 2011 04:44 PM
Overclocking the ASUS GTX 580 Voltage Tweak Edition Comment Thread SKYMTL Video Cards 45 December 24, 2010 04:47 PM
GTX 580 overclocking ToXic Video Cards 6 December 18, 2010 12:09 PM
overclocking E6300 on evga 680i!! oksir Overclocking, Tweaking and Benchmarking 3 January 15, 2009 06:36 PM
