-   -   Radeon HD 6 series question (http://www.hardwarecanucks.com/forum/video-cards/40401-radeon-hd-6-series-question.html)
BFighter February 1, 2011 09:05 AM
Are there any watercooling things for them? Like the Vapor-X from Sapphire.
Any waterblocks?
FreeKnight February 3, 2011 08:42 PM
Don't know for sure about waterblocks, but FYI Vapor-X isn't a watercooling add on. It uses moisture in the cooling pipes, but it's a closed self-contained systems. If you try pumping coolant into it, well you'll just make a mess :D
I'd maybe check Koolance or other waterblock manufacturers, they might have something
Prolab February 4, 2011 12:00 AM
Koolance and EK have blocks for the AMD 6000 series video card.
