  #21 (permalink)
Old January 29, 2011, 12:50 PM
Is this score decent?
Result
  #22 (permalink)
Old January 29, 2011, 01:48 PM
meh 3dmark i use mostly for stability, power figures.
get fraps or something along those lines, load up your game and play it
see how it feels at the given resolution/quality settings.
and then check out fraps. see what the lows were. thats the most important part, the lows
because of theose bastuges that your game can be not quite enjoyable.
they say 30 fps is the minimum. some others say 60 fps being a minimum
i just go by feel. if i see any jerkiness, i work out the oc/resolution/quality settings if not
i could care less about a few fps more or less than the other guy
Confused over 6pin and 8pin, and power capacity of pcie plugs 0o0 Power Supplies 7 February 1, 2010 02:58 AM
Not enough sata power connectors book0006 Storage 5 January 13, 2010 10:46 AM
PCIe slot power consumption? sswilson HardwareCanucks F@H Team 66 January 12, 2010 07:53 PM
Custom sleeved 6 plug Pcie power cable Alwaysrun Power Supplies 2 May 17, 2009 05:37 PM
Power Connectors tim333 New Builds 4 April 9, 2009 09:56 AM
