Old January 27, 2011, 06:57 PM
r0k0's Avatar
Default Sapphire 5970
So i upgraded from my old MB / CPU / Ram and now i cannot run Again Crossfire..
and i've installed the 11.3 and their 2 option tab in GPU-Z you click on 1 core CFX is Disabled and then the Second 5900 tab the CFZX is enabled...
anybody have this problem ?
Main Rig
Intel Core i5 2500K - 5.0
Asus Maximus Gene-Z / Gene 3
4x 4GB Corsair Vengence DDR3-1600
AMD Radeon HD 6990 4GB 880 / 1300
Crosair 600T White / Enermax Revolution 920W
A-DATA 120GB SATA3 SSD / Seagates 1TB Spare SATA3
Canadian Eh ?
Old January 27, 2011, 07:12 PM
lowfat's Avatar
You don't have to enable Crossfire w/ the HD5970. It is always enabled.
Old January 27, 2011, 07:18 PM
r0k0's Avatar
GPUz says its disabled and previous owner said it had to be enabled to have both GPU active while gaming
Main Rig
Canadian Eh ?
Old January 27, 2011, 07:33 PM
lowfat's Avatar
Have you tried running a game to see if both cores are being engaged?
Old January 27, 2011, 08:03 PM
r0k0's Avatar
how do i see if both core are engaged while gaming ?
Main Rig
Canadian Eh ?
Old January 27, 2011, 08:27 PM
lowfat's Avatar
Open two instances of GPU-Z. One for each GPU. Then launch a game. Quit the game and look to see if both cores had a load on them.
Old January 27, 2011, 08:50 PM
r0k0's Avatar
ok.. and now i cannot play dragon age for some physx problem and mafia 2 wont boot...?
Main Rig
Canadian Eh ?
Old January 27, 2011, 09:30 PM
ern88's Avatar
Did you use driver sweep to totally remove the nvidia drivers? You probably have some lingering around. It's a free program.
Old January 27, 2011, 09:35 PM
lowfat's Avatar
They won't launch because you deleted the PhysX software. Download and install this.
NVIDIA DRIVERS 9.10.0513
Old January 28, 2011, 01:42 AM
r0k0's Avatar
are we not supposed to run nvidia and ati at same time ?
Main Rig
Canadian Eh ?
[FS] LNIB Sapphire 5970, 2 HP L2445M monitors Branched Buy/Sell & Trade 16 September 1, 2011 03:01 PM
Sapphire 5970 in a Lian-Li PC-7FNWX? phiiil New Builds 6 June 17, 2010 08:15 PM
[FS] F/S: Sapphire 5970 OC Edition gerardfraser Buy/Sell & Trade 12 January 30, 2010 12:42 AM
