  #51 (permalink)
Old January 26, 2011, 12:58 AM
GT7R's Avatar
Great review as usual, a joy to read.
  #52 (permalink)
Old January 26, 2011, 05:29 AM
Arinoth's Avatar
Originally Posted by Dreamsickle View Post
Or better yet, the Gigabyte GeForce GTX 560 Ti SOC (GV-N560SO-1GI).
Core Clock: 1000 MHz
Shader Clock: 2000 MHz
Memory Clock: 4580 MHz
STOCK!
Overclocked mine to:
Core Clock: 1044 MHz
Shader Clock: 2088 MHz
Memory Clock: 4950 MHz
What are your temperature and noise like, i considered the Asus one a winner as its idle and load are the coolest while being the quietest out of the cards i've seen reviewed so far.
  #53 (permalink)
Old January 26, 2011, 05:55 AM
It sounds like he wrote the review for Guru3D as those were the overclock numbers attained. The noise was not noticable says the review. The temps are also very good at 29C Idle and 60C after "intense" gaming.
Can't wait for Newegg or NCIX to get these instock.
  #54 (permalink)
Old January 26, 2011, 06:09 AM
Arinoth's Avatar
I hope thats the case as i'd like to replace my rather noisy 6870s with 2 560 Tis for surround gaming. I should be able to overclock and run them in sli as i am running a tech station and can populate the cards in pcie1 and pice3 slot so lots of space for air flow
  #55 (permalink)
Old January 26, 2011, 06:24 AM
Haha! Yeah, I just copied the settings they did in the review, since my system is better than the one they ran I figured if they had good/stable results from that so would I. Saves time fiddling with adjusting the settings in small increments and running benchmarks again and again. Sure, I might be able to go a little bit further, but I'm not really concerned with spending several hours to get a 1-2% performance increase. As far as noise is concerned I don't have the equipment to measure it, but I wouldn't say it was any louder than the plethora of case fans in my system (I also didn't adjust the fan speed any). Temperatures are well within safe ranges as well. In SLI though, since I'm using a Gigabyte GA-P67A-UD7 the slots are right next to each other so one tends to run ~6-7°C hotter. Also, I remember reading somewhere that Fermi-based cards are engineered to safely operate at up to 90°C; however, I'm not sure I believe that. If it's true, then this card runs really cool in comparison.
Still, even with the regular, stock (and warrantied) overclock, it should outperform the ASUS GTX560 Ti DirectCUII TOP.
P.S. Only one SLI connector so if you're planning to 3-way SLI these, you can't.
  #56 (permalink)
Old January 26, 2011, 07:13 AM
Soultribunal's Avatar
Most mid range cards aren't setup for 3 WAY SLI anyways. Usually people with that type of money anyways will go with the flagship cards.
As for the rated temperature, I would actually agree with what nVidia states as thus far its proven fairly accurate.
My GX2's would run Folding in the 85's-90's. Safe Temp for the G92 core was, 110 or something like that. In the 2 straight years of Folding, not one card ever failed.
ST
  #57 (permalink)
Old January 26, 2011, 09:38 AM
Dark-Colonel's Avatar
Damn you nVidia, I felt awesome buying a used GTX470 for $200 just two months ago and now I already feel like I'm 2 years behind >_<
Heatware
[ 72 - 0 - 0 ]
  #58 (permalink)
Old January 26, 2011, 12:54 PM
r0bc's Avatar
It looks like a great card but does it do DTS-HD/DolbyTrueHD like the 460 or is that just a given now?
  #59 (permalink)
Old January 26, 2011, 01:23 PM
SKYMTL's Avatar
HardwareCanuck Review Editor
It's a given now. Especially with the included HDMI 1.4 connector.
  #60 (permalink)
Old January 26, 2011, 09:42 PM
Tell me about it I got the GTX 460 in September and the best sale I could find was $230 CAD, now they are usually $180 CAD without looking too hard. Damn, and after taxes and IRP, they were almost $270 each :(.
NVIDIA GeForce GTX 460 SE 1GB Review Comment Thread SKYMTL Video Cards 24 May 12, 2012 01:35 AM
NVIDIA GeForce GTX 570 Review Comment Thread SKYMTL Video Cards 82 December 14, 2010 07:50 PM
NVIDIA GeForce GTX 580 Review Comment Thread SKYMTL Video Cards 186 December 8, 2010 02:29 AM
NVIDIA GeForce GTX 460 1GB & GTX 460 768MB Review Comment Thread SKYMTL Video Cards 126 August 20, 2010 10:01 AM
