Old January 24, 2011, 10:37 AM
personally i think you should opt for the 6950 then. there is one on at ncix, powercolor for 279. you can score a sapphire for 289 on newegg iirc.
Old January 24, 2011, 04:29 PM
Galcobar's Avatar
Originally Posted by Eagle Eye_54 View Post
Why do you suggest AMD over a comparable NVidia? Curious if there is something about the two chip makers I am not aware of. Which brand fo you prefer and why? e.g. Is XFX better than eVGA, Sapphire or HIS?
IF the budget is $300, then the best card you can get under that budget really is the 6950. A GTX 570 is significantly over $300, while a GTX 460 -- which is rapidly approaching EOL -- is significantly slower though at ~$200 is good bang-for-the-buck.
Trouble is right now that there really isn't a comparable Nvidia around the $300 mark.
Old January 24, 2011, 04:41 PM
I'm not sure on length, as I'm more likely to stick with nvidia (and therefore don't pay too much attention to ATI), but if you are looking at ATI, I'd stick with the 68xx series as they still have the traditional role of being more power-efficient and run cooler than their nvidia counterparts (and you said that was important). I usually will not suggest ATI unless you play 2560x1600 or the price warrants the suggestion, but if I were to suggest ATI, that would be my suggestion.
The GTX 460 1GB is a great option, or you can see how well the 756MB in SLI works if you nab it at $130 each (or less). I would never suggest a single 756MB card for medium-high level graphics, but maybe in SLI they are worth it?
Old January 24, 2011, 05:29 PM
A mysterious card showed up at my house the other day in a static bag. Couldn't really say what it is, a new offering from NVIDIA I believe. The performance is there, and the price will be right.
I'd say hold on a very short while OP- don't buy today. I'm thinking this card will be desirable to you.
Intel 990X/ Asus Rampage III
Patriot 3 X 2GB
GTX680 SLi
Dell 3008
Old January 24, 2011, 05:39 PM
Delavan's Avatar
I'd grab a GTX570 on sale. NCIX was selling a ZOTAC (lifetime warranty) for $319 a few weeks back...
Especially if you wanna buy a card that will last you 3 years like you say...get the fastest card you can get!
I'd say hold on a very short while OP- don't buy today. I'm thinking this card will be desirable to you. __________________
I guess the Rollo dude is talking about the GTX560!!!
i5 2500K @ 4.5GHz / NH-U12P / P8P67 DELUXE / 8GB Corsair Vengeance Arctic White 1.35V 1600 / 2 x N560GTX Ti Twin FROZR II OC in SLI (8823 3Dmarks11 P-score)/ Corsair Performance Pro 128GB SSD
Old January 25, 2011, 06:46 AM
it was based just on budget, no nvidia card that can outperform a 6950 is less then 300. the new 6950 1gb are out now, and they are starting at 259 on newegg
Newegg.ca - SAPPHIRE 100312-1GSR Radeon HD 6950 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
im not too picky about brands, usually the cheaper one, or if one comes with more accessories. also some brands have better warranty then others. all preference at the end of the day, for the most part they will all perform the same
edit: i should mention stock for stock. overclock is always a variable, but its not guaranteed
Main|Xeon w3520 #3845a @ 4.2ghz|Rampage III Extreme|2x6950 unlocked CFX|3x2GB Corsair Dom GT 2000|Intel x25-m 160GB|Obsidian 700D
Weekend|i7 920 #3910a @ 4.2ghz|X58A-UD7 Rev 1|2xEVGA GTX 460 2GB SLI|3x2GB Mushkin Blackline 1600|Corsair F120|Raven RV01
AMD HTPC/Game Cube|Phenom II x4 940 BE|Biostar A780L mATX|XFX 6790|2x2GB Crucial Ballistix Tracer 800|WD Black 640GB|APEVIA X-QPACK2 (red)
Racing Sim|Playseat Evo|Fanatec GT3RS v2| 55" Samsung Plasma
Old January 25, 2011, 07:00 AM
either 560 or 6950 1b/2gb(depending on price) to be grabbed :)
Old January 25, 2011, 12:19 PM
Pukka's Avatar
I'd say get a 560; or, if you are brave, get a 6950 2GB and unlock it to a 6970. It worked like a charm for me
  #19 (permalink)
Old January 25, 2011, 07:41 PM
good. if you want to try it, 6950 modded bios.
  #20 (permalink)
Old January 25, 2011, 09:54 PM
Yeah thanks. I heard that the 6950 can flashed to the 6970 specs. I may just do that.
Caveat Emptor
EYEFINITY-Monitor input/GPU output issues... Rikan S-087 Troubleshooting 7 January 18, 2011 02:44 PM
Upgrade GPU?? mjpd1983 Video Cards 13 November 15, 2010 02:34 PM
GPU Upgrade time Cptn Vortex Video Cards 15 August 20, 2010 07:24 PM
Best GPU upgrade for the $$ SneakySnake HardwareCanucks F@H Team 5 May 12, 2010 07:26 AM
WTB: Wanted, ANY GPU block that can fit a HD3450 b1lk1 Buy/Sell & Trade 8 May 7, 2008 05:18 AM
