<~----> GTX 460 Upgrade - Hardware Canucks
Old January 23, 2011, 11:52 AM
Default GTX 460 Upgrade
Greetings,
I was thinking about upgrading my current GPU to a GTX 460 but confused on which to get (ie. 768MB/1GB, MSI/Galaxy/EVGA/PNY etc). I would mainly play Empire Total War/COD Black OPs. Also, would I need to upgrade my PSU as well?
If anyone kind enough to give me some assistance, I would greatly appreciate it. My current specs listed below:
Dell XPS 435T/9000
Windows 7 Ultimate 64-bit
Intel I7 920 2.67 Ghz
BFG GTX 260 maxcore 55 nm 896 MB
8 GB DDR3 1066 Mhz (Dell stock)
PSU Dell stock 475 W
Thanks!!
Old January 23, 2011, 11:58 AM
yamawho's Avatar
If you game over 1920x1080 res than it's better to get 1GB of ram. Otherwise 768 is great!
I upgraded from a GTX260 core 16 and got a 20% increase in fame rate in FarCry 2, purchased this one ...
NCIX.com - Buy EVGA GeForce GTX 460 Superclocked Fermi 763MHZ 768MB GDDR5 Dual DVI Mini-HDMI PCI-E DX11 Video Card - 768-P3-1362-TR In Canada.
Old January 23, 2011, 12:23 PM
If you can get a good deal on a 1GB go for that. It really depends on the resolution you plan to play on. The 460s are great values regardless. I've tried some of the top cards and still go back to the 460s for my needs. The new 560s are being released this week too but at a higher price range.
Old January 23, 2011, 12:37 PM
it is going to be a jump, but not a stellar one.
one things for sure though, your psu will be ok
if it kept the 260 at bay : power numbers
edit : if you believe chinese 3dmark numbers : Nvidia's GTX 560 Ti Gets Torn Apart Ahead of Launch, Uses Improved Cooling System - Softpedia
Old January 23, 2011, 02:25 PM
As said above, you will see an improvement but I don't think it is going to be an amazing upgrade. If you game at HD or lower resolution a 768mb should be fine, but if you can get a deal on the 1gb then go for it. Maybe wait and see what the gtx 560 brings to market and possible pricing changes if you can.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old January 23, 2011, 04:14 PM
Excellent suggestions. Very much appreciated. @yamawho, Im in for one. Thanks alot
Old January 23, 2011, 04:25 PM
yamawho's Avatar
Glad to be of service
Old January 23, 2011, 04:41 PM
I think waiting for 1-2 months would be a good idea. If you're going to upgrade, make it significant so you are content with it.
Old January 23, 2011, 05:19 PM
yamawho's Avatar
Performance is one point but value is the other consideration.
If you cab get a 460 for 140$ and improve frame rates 20%, is spending another 100$ more to get 5 to 10% more worth the extra cost?
Old January 24, 2011, 08:05 AM
Yeah the 560 will be officially released (the NDA) tomorrow. It will be between 250-300$ (depending if you take it stock or pre OC'd). Gigabyte will have a 1ghz (GPU) special version (from 822 standard) so that mean it will be an excellent overclocker like the 460.
GTX 570, GTX 460 1GB SLI or AMD alternative(s)? Zak_M Video Cards 4 December 18, 2010 05:43 AM
NVIDIA GeForce GTX 460 1GB & GTX 460 768MB Review Comment Thread SKYMTL Video Cards 126 August 20, 2010 10:01 AM
GTX 460 VS GTX 470 for folding Scottyboy85 Video Cards 29 July 15, 2010 12:54 PM
