-   -   XFX 6950 + CRT as a secondary monitor (http://www.hardwarecanucks.com/forum/video-cards/40023-xfx-6950-crt-secondary-monitor.html)
Prolab January 19, 2011 03:43 PM
I just bought the XFX 6950. So far so good, a very good upgrade from my 4890. However, i can't connect my CRT monitor to the secondary DVI output (besides the exhaust).
If i switch between my LCD and CRT monitor, DVI output 1 works. It both recognizes it. But if i put the LCD on the output 1 and the CRT on output 2 (or vice versa), extended desktop wont work.
I went to CCC and look for the secondary panel, it doesnt show up.
But if i go to my desktop and right click, i have to force it to connect by VGA. But yet, it still wont save the changes.
Does the card support VGA at all or no?
zoob January 19, 2011 04:25 PM
Only the main one next to the two mini display ports supports VGA and dual-link DVI.
If your LCD resolution is 1920x1200 or less, bump that to the bottom DVI slot and use the DVI->VGA converter on the top one. If you look at the pci slot bracket you can see an embossed "VGA" text.
Or you can buy a minidisplay port->VGA converter on amazon for $10
Prolab January 19, 2011 06:01 PM
What a N00b mistake...
Thanks Brian!
