Old January 15, 2011, 12:42 PM
schweppes's Avatar
Default 76'0 c in game too hot ?
what kind of temperature is considered 'too hot' for a card to run at?
it idles around 32 just sitting at the desktop. but goes much higher obviously.
this is a gtx580 with
haf932 case
rampage formula iii mobo, i7950 cpu
i also have the corsair h70 water cooler hooked up pull air in, with the resistors plugged in to turn the fan speed from 2000rpm to 1600. stock fans on the case, didnt change anything, except removing the CM fan at the back to replace with H70.
should i change the push/pull configuration in my case? or basically should i be concerned at all for these in game (bf:bc2, civ5 for example) temps of up to 76'0?
Old January 15, 2011, 12:43 PM
CMetaphor's Avatar
Quadfather
Dont worry about that. 76 is just fine for a video card. Start worrying if it cranks above 90-95c
Old January 15, 2011, 12:48 PM
chubaka's Avatar
my watercooled 470 is 60 degrees...=.= urs is fine
Old January 15, 2011, 12:51 PM
no worries maite, add a second one in sli and get near cmet's numbers :)
Old January 15, 2011, 12:55 PM
schweppes's Avatar
can it be pushed hotter? for OC'ing or what not? im using the program 'msi afterburner' for monitoring there is a simple slider where i can push the core clock/ shader clock much further than stock. how hot can it go and be in a safe zone?
Old January 15, 2011, 01:01 PM
5 series are tweaked 4 series. now any 4 series owner will tell you that they run pig hot. as in around meta's numbers when case temps arent seriously cool and the fan not on 75+ %.
so youre good up to maybe...80-90?
Old January 15, 2011, 01:14 PM
90 is where I'd start to worry a little bit. 95 is when you need to adjust the fan speed permanently :P
You definitely have some OC'ing headroom.
Old January 16, 2011, 10:13 AM
schweppes's Avatar
sweet. thanks dangtx, JMCD, CMetaphor and chubaka!
Old January 16, 2011, 12:03 PM
Fudd Rucker's Avatar
Is that with a full coverage block or a gpu block + sinks for mem and VRM?
Im asking because my gtx 480 runs 875/1750/4200 all day every day running einstein@home and the gpu has never once gone over 50 degrees.
I couldnt think of something snarky or interesting to put here this time around.
Old January 16, 2011, 03:10 PM
belgolas's Avatar
I used to have my 480's at 100c for very long periods of time. It got up to 105c a few times. You are way under the thermal threshold.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Favorite game console's and game's SEGACDX Gaming 24 September 1, 2010 11:37 PM
Hot summer days, hot computer problems. NightRain Air Cooling 17 July 6, 2009 09:11 AM
Game/Game Servers Recomended to Try cdn_Madrach Gaming 0 August 17, 2008 07:21 AM
how hot is hot? Scratch Overclocking, Tweaking and Benchmarking 7 January 16, 2008 10:15 AM
