Originally Posted by chriskwarren You have an 1100w psu...what brand is it? Any specs? Do you have another PSU to try? Also double-check that you have used proper power connectors and that they are fully inserted.
Also make sure that when you installed the drivers from nVidia, you selected the "Clean" install option to get rid of all the old driver stuff (believe its found in "Custom" install). |
The 1100W unit is a Dell Branded Delta in those, (Delta Makes most Antec) so he should be good on the power front.
I'd also second the option to do a clean install so that way it nukes all the old stuff. Driver sweeper never hurts either, that has to be done in safe mode.
ST
