Old January 6, 2011, 09:41 PM
Blu's Avatar
Blu Blu is offline
Default What way does the card push air?
Which way does a video cards move air? Does it suck it in and go like this?
Or does it pull it from outside and exhaust into the case like this,
So how does this work? I've always sorta wanted to know how a PCI cooler would help if it was blowing cool air on the card, or sucking it out from the fan and out the back of the case so any help would be great.
Old January 6, 2011, 09:46 PM
MacJunky's Avatar
Presuming you have a similar cooler on your GFX card, crank the fan speed and put your hand behind your case.
Old January 6, 2011, 09:51 PM
JD JD is offline
It typically blows/exhausts out the back, so like your 1st drawing.
Old January 6, 2011, 09:56 PM
unless you reverse the wires on the fan it goes out the back :) fresh air towards the blower area does help, as some form of exhaust on top where heat will emanate, if you can call it that :)
Old January 6, 2011, 09:59 PM
ZZLEE's Avatar
Use a Ligter ( not to close to anything flamable ) will show you air flows. :)
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old January 6, 2011, 10:42 PM
My hd4870 its hard to tell, it blows out but just barely. And ive cleaned up all the blades and fins. Seems like as much hot air gets dumped in the case as goes out the back.
Old January 6, 2011, 10:49 PM
rjbarker's Avatar
Exhaust out the back...intake at the front..
Firestrike Extreme: 21.452
MARK 11: 32.530
Old January 8, 2011, 04:09 AM
No.1
Axial fans pull air from the centre and push it out.
Reversing the fan greatly diminishes efficiency
Old January 8, 2011, 06:27 AM
Bond007's Avatar
diagram 1...it sucks in at the fan and blows it out the vent holes on the back of your case.
Can i push this further on air than it already is? BrianHanna Overclocking, Tweaking and Benchmarking 10 January 3, 2009 09:10 PM
