Old January 6, 2011, 08:44 PM
Numfar's Avatar
How about three 40" LCD tvs...the best of both worlds? It could work in theory right but might be hard to find a slim enough bezel? Am I nuts;p Oh yes and it might take a bit of space:)
Old January 6, 2011, 08:45 PM
yes, and it might take a bit of $$$, LoL...
Old January 6, 2011, 09:32 PM
i have yet another question...
i have 3 monitors setup on eyefinity...1 22" dvi-d that's connected to the mini-displayport adapter...1 19" dvi-d that's connected to the dvi port...1 19" d-sub that's connected to the dvi port thru a d-sub to dvi adapter...
if i want to add a 32" display thru hdmi, will my existing eyefinity setup not work anymore?...i don't think there'll be any impact...if anything, the additional 32" would be a "separate" screen, or could even be merged as a 4TH screen to the eyefinity (even tho that's not what i'll do), right?...
Old January 6, 2011, 10:15 PM
Samsung has the 3 monitors in 1 covered with the MD230X3.
Available at NCIX for $1,899.99 plus tax's and applicable fees.
P.S. If you had $3,391.30 plus tax's and applicable fees burning a hole in your pocket you can get the
Samsung MD230X6 for yourself.
Old January 6, 2011, 11:37 PM
Supergrover's Avatar
Myself I would go with a large main 30" monitor and keep the 22 as a "spare". IE I use my secondary as for temp monitoring, IM programs, irc and torrent client. Not to mention it is a godsend if I am gaming and am using a Guide or map. Just some food for thought.
R.I.P.
Old January 7, 2011, 12:29 AM
It's only worth it if you upgrade your resolution. No other reason.
30" 1600 is overpriced but that is changing.
https://www.hazro.co.uk/shop.html#ec...roduct=1510352
https://www.hazro.co.uk/shop.html#ec...roduct=1569972
Old January 7, 2011, 02:13 PM
hummm...so it turns-out i can't have 4 monitors on my eyefinity setup...i plugged-in my 32" via hdmi, tried to extend my desktop, and bam, it asks me to disable one of my other monitors...
Old January 9, 2011, 12:57 PM
belgolas's Avatar
You can have 4 monitors IIRC
• A maximum of 2 legacy monitors (VGA, DVI or HDMI) can be enabled simultaneously, provided that each monitor is connected either directly or via a “passive” DisplayPort™ adapter/dongle. “Passive” adapters/dongles will NOT support more than 2 legacy monitors.
• To enable support for more than 2 monitors, “active” DisplayPort™ adapters/dongles are required (or monitors with direct DisplayPort™ connectivity must be used).
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
  #19 (permalink)
Old January 9, 2011, 04:52 PM
Hey all! Since this is kind of related I will try asking here first.
I just built myself a triple screen racing rig. I have purchased an HD 6950 to run it but have not installed it yet, however I understand it will support 4 monitors. What I want to be able to do is either have the 3 screens running OR the single screeen on my desktop. I don't have any experience with eyefinity yet.
So, I guess I have a few questions. If the triple setup is running how will that affect the single screen on my desktop? Is there a way to set it up so that I can choose between the two (ie: setup a keystroke that will choose between the rig and the desktop?). Is that something that I can either do or choose between in the control center? Will the card know that it is running 1 setup in triple monitor and 1 single monitor?
As you can see, I am very very noob in the multi-screen world. Any help would be very much appreciated.
RJ
  #20 (permalink)
Old January 9, 2011, 08:26 PM
From my understanding, all setup is thru the catalyst control center (CCC). Thru the software, your card will know what to do. You can set the 3 monitors to run in a group, and have the 4th monitor as an extended desktop thru CCC.
However, hardware-wise, i'm not sure how to do the 4 monitor setup. I've been researching and asking around, but no bites. I may try the following and see if it works.
1 dvi monitor to the mini-display port, using an active "mini-display port to dvi" adapter
1 d-sub monitor to the mini-display port, using a "mini-display port to vga" adapter (from my understanding, these are all "active")
1 hdmi monitor thru hdmi port
1 dvi monitor to the dvi port
This is gonna be trial-and-error. If the "mini-display port to vga" adapter doesn't work, i'm screwed, as i won't be able to return the opened item. Sigh...
3x Monitors - Need opinions! tkd Video Cards 19 June 11, 2010 11:52 AM
Where have all the 19" monitors gone Roger Franklin Off Topic 6 September 13, 2008 11:48 PM
cables for monitors Tazer-[X] Troubleshooting 9 July 16, 2008 11:08 AM
Big screen TV as monitor tech_joe Display Units 15 July 3, 2008 11:17 PM
2 Monitors ih8purple Display Units 3 January 22, 2008 11:09 PM
