<~----> GTX 580SC Tri SLi Madness :) - Page 2 - Hardware Canucks
Old January 6, 2011, 01:51 PM
kruzn4evr's Avatar
Very nice Bob!...thats the way to do it .....now if only you were watercooled you probably would break 60k easy
Old January 6, 2011, 04:08 PM
rjbarker's Avatar
Yeah your right Bob......as soon as I go over 900 Mhz its 50/50 whether I get through the run or not.....I'll probably get everything ready and try for "high run" tomorrow....think I'll try the new Beta Driver as well..
Is that a TRUE on your cpu?
Correct, that is a TRUE (push / pull).....the Case is getting old now....but still so functuional, maybe next time I do a complete strip I'll throw some some black paint in the interior.
Old January 6, 2011, 04:09 PM
belgolas's Avatar
That is pretty awesome! Me so wants!
He doesn't need to water cool the GPU's as they are already cool enough. Remember he still has 25 more degrees of room. The CPU he could water cool and maybe get more out of it to break the 60k score.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old January 6, 2011, 04:36 PM
kruzn4evr's Avatar
^^ thats true, I tend to forget they run alot cooler, me thinks its time for a voltage bump to break that 900 mark. WC'ing the CPU would help, maybe you should consider doing a ghetto outside the case CPU loop, pick up some used parts from here and give it a go
Old January 6, 2011, 04:44 PM
Arinoth's Avatar
I agree with others saying you should at least WC the cpu as long as you stayed with the same chipset, and when you upgrade just buy the replacement backplate. You could push that cpu more and get even higher score.
Old January 6, 2011, 04:59 PM
gingerbee's Avatar
yup water cool the bad ass 980x. very nice rj
Old January 6, 2011, 05:31 PM
rjbarker's Avatar
I'm actually planning a 2nd build (with used parts), so the 3rd 580 will likely go into that build.........thanks for the comments guys !!!!
Old January 6, 2011, 08:29 PM
belgolas's Avatar
If you are lazy like me the H70 is pretty nice.
Sponsor a child!
Fight poverty.
Qoute by Perineum
  #19 (permalink)
Old January 6, 2011, 09:02 PM
rjbarker's Avatar
^^^ Actually the H70 isn't any better than a TRUE (push / pull config)....
  #20 (permalink)
Old January 6, 2011, 10:06 PM
CTA's Avatar
CTA CTA is offline
how about phase change machine? a guy at here is selling one...
NEW: customize case, hx100, i7 920, supreme hf, x58 sabertooth, 3gbx2 ram of ripjaws, xfx hd6950 CF. vertex 2 60gb, seagate and hitachi 1tb, dual mcp355 with ek rex v2, 2x koolance ar697, 2x mcr320, 6x zm-f3 fans.
OLD: cm 690, hx620, intel q9450, True Black, ga-ep45-ud3p, 2gbx2 ram of mushkin xp2 8500, xfx 285. wd caviar se16 640gb, 4x zm-f3 fans.
NCIX Aberdeen MADNESS Perineum Off Topic 40 November 18, 2009 05:51 PM
HL2 Madness SuperFriedFish Gaming 7 March 17, 2009 09:09 PM
Ableton DJ Road mix machine Madness 2.0!! Cptn Vortex Case Mods, Worklog & Gallery 8 January 16, 2008 11:58 PM
Moduslink madness! Babrbarossa O/S's, Drivers & General Software 15 June 3, 2007 01:04 PM
