Old December 31, 2010, 02:53 AM
Default 9800GT Problems
Hi guys !
I have posted this thread to nvidia forums, but I haven't got any replies yet so I though I could get some help in here.
First of all here is my computer specs:
Processor: Intel® Core™2 Duo CPU E8400@3.00GHz (Ninja Scythe cooler, huge thingy)
Memory: 2x2GB sticks = 4094MB RAM DDR2@800Mhz (Page File: 1528MB used, 8644MB available)
Motherboard: Asus P5B (BIOS Date: 03/09/09 10:13:49 Ver: 08.00.12)
PSU: can't remember the manufacturer but it gives 640W.
OS: Vista 64-bit home premium
GPU: nVidia 9800GT 512mb.
GPU driver: 8.17.0012.5896, Forceware 258,96
I use MSI afterburner to set the fan speed of the GPU's cooler.
I have figured out, that the fan speed = power, in my 9800GT. For example: when the fan speed is set to 35% my rig gets 8000 points in 3Dmark06, but if the fan speed is set to 100% I get nearly 12 000 points.
Alright so here's the problem:
When I play new games like Mafia 2 the 9800GT works just fine, fps stays 40ish.
But after 5-10min of gameplay the GPU's fan throttles back to auto mode (35% fan speed). I have tried to play on like 800x600 resolutions and settings low , but same thing happens over and over again.
After that the GPU usage drops below 50% while the game is still running.
Well here it is, major problem of this card. Thanks guys !
I snapped a screenshot of the MSI's afterburner: http://img823.imageshack.us/img823/4...sonofaduck.jpg
E: Core voltage stays stable @ 1.05v I don't know about the amps.
Old December 31, 2010, 10:41 AM
Coach's Avatar
have you cleaned the HSF on the card? ever?
Old December 31, 2010, 11:23 AM
well im thinking it is throttling down due to heat, so as per above.
not only the core, but other chippies as well.
if youre handy, take the stock fan and shroud out and point a 120mm very close by to beat down on the card. less noise, better cooling :)
Old December 31, 2010, 12:03 PM
Max temp is 75C what I have seen so far.
Old December 31, 2010, 12:38 PM
Coach's Avatar
ok, but is the hsf clean or is the card throttling bc it is full of dust bunnies?
Old December 31, 2010, 01:03 PM
My card looks like this . The hsf and the fan are pretty huge.
Well, there is some dust but not particularly much. The temperature isn't fatal yet tho
E: I should mention that the card has begun to crash often ! Like every time, when I start up the computer and go see a youtube video. Screen blinks and a text pops up: "Graphics card stopped responding and recovered." The card might be broken... Oh well, I have been looking for new card tho.
Old December 31, 2010, 02:10 PM
if the hsf trick wont work, some may say bake it but i say meh.
amd hd 6850 , dont go lower.
Old December 31, 2010, 03:51 PM
I have been looking for GTX 460 hawk or the gigabyte one.
Old December 31, 2010, 04:03 PM
or that. look up performance here : HIS Radeon HD 6970 2 GB Review - Page 29/33 | techPowerUp
and then look at the graph that best depicts your scenario, like resolution.
Old December 31, 2010, 08:25 PM
Trial Member
Default I got the same problem
9800gt (evga) problems fix0r75 Troubleshooting 10 August 13, 2010 07:51 PM
[WTB] 8800GT or 9800GT darksideleader Buy/Sell & Trade 8 November 15, 2009 10:47 AM
9800gt CTA Video Cards 5 December 27, 2008 05:58 PM
9800gt or 4850? donimo Video Cards 11 October 2, 2008 09:20 PM
