Old December 29, 2010, 11:25 PM
Trial Member
Default Major Crossfire Problems! HD5850
Hi guys,
Could you help me with my crossfire setup or lack-there-of.
My specs are the following;
eVGA X58 classified 3-way SLi
6GB Corsair Dominator GT
Sapphire HD5850 2x
2x 1tb Segate 7200.12
2x 32GB Corsair Nova SSDs.
Windows 7 Ultimate 64bit
I've installed the catalyst profiles, disabled catalyst AI.
3DMark vantage gave me a score of
P10698
CPU: 19585
GPU: 9292
From what I've read this is seriously off the mark :S I have no idea what the problem is as this is the first time I've tried setting it up.
Any ideas why??
Old December 30, 2010, 11:33 AM
If i remember correctly, you need to enable AI otherwise only one card is using and Xfire is OFF
Old December 30, 2010, 02:58 PM
dustin1706's Avatar
As long as you have a crossifre bridge between the cards and crossfire is set to enabled in CCC, it should be working. No need to tweak any other settings in CCC. The easiest way to be sure it is working is to use a program like MSI afterburner and set it up to monitor GPU usage and temperature on screen (OSD). That way, you can see if both GPUs are being utilized in games and in benchmarks.
I am assuming that you are running the latest drivers and latest version of CCC as well. Not that the older ones don't work, but I do like the new CCC much better.
MSI GT72 6QE-033US - 6700HQ, GTX980M, 1080p G-Sync IPS, 16GB DDR4, 1TB Evo 850 SSD, 256GB Toshiba SSD, 2TB Barracuda, BD-Rom/DVD-RW
Old December 30, 2010, 03:13 PM
+1...Crossfire only works with AI enabled.
Old December 30, 2010, 04:13 PM
Dr_BenD_over's Avatar
Fallen Folder
Even with only one card active, that's low for a 5850. Double check your settings in the CCC. (AA AF and V-Sync off, Cat Ai ON)
All's well that's Haswell
Old January 6, 2011, 01:44 PM
the fix has already been posted Disabling Cat AI disables optimizations that ATI uses but more importantly it completely disables crossfire. Meaning by turning Cat AI off you have effectively cost yourself about 10% performance wise in single gpu mode and if your running dual card you've lost Crossfire. To fix the issue simply turn Catalyst AI back on and your good to go.
2x HD5850 CROSSFIRE or ATI Radeon 5970 2GB GDDR5 Ram Alexanderrazz Video Cards 10 June 28, 2010 06:13 AM
GTX480 + 8800GTX major problems Overclocker~4.1 Troubleshooting 8 June 23, 2010 09:10 PM
[WTB] HD5850, true120/venomous/nh-d14, wd black 1tb 0o0 Buy/Sell & Trade 12 May 10, 2010 05:37 AM
HD5850 HDMI issues Brando737 Video Cards 3 April 28, 2010 12:05 PM
