Old December 29, 2010, 01:28 PM
Blu's Avatar
Blu Blu is offline
Default What graphics card do I pick for my HTPC
So I got down to 2 cards for my htpc, I've been told they will process the larger .mkv movie files better then just the onboard hdmi port. I've got it down to two,
NCIX.com - Buy MSI GeForce GT 210 589MHZ 512MB DDR3 PCI-E VGA DVI HDMI HDCP Low Profile Video Card - N210-MD512D3H/LP In Canada.
For $12.99 after the rebate
Or
Newegg.ca - ZOTAC Synergy Edition ZT-20303-10L GeForce 210 1GB 128-bit DDR2 PCI Express 2.0 x16 HDCP Ready Video Card
For $25 after the rebate
Please help suggest one quick, or should I just stick to my onboard HDMI?...It's such a tough choice...
Old December 29, 2010, 01:30 PM
Arinoth's Avatar
Well what is the onboard chipset/graphics card?
Here I am: here I remain
Old December 29, 2010, 01:45 PM
Blu's Avatar
Blu Blu is offline
880GMA
NCIX.com - Buy Gigabyte 880GMA-UD2H AMD880G mATX AM3 DDR3 1PCIE CrossFireX DVI HDMI GBLAN SATA3 USB3.0 Motherboard - GA-880GMA-UD2H In Canada.
Old December 29, 2010, 01:59 PM
keep the onboard maite :)
Old December 29, 2010, 02:03 PM
Arinoth's Avatar
You do not need an external graphics card. The onboard graphics card provided you run say at least 2 GB of ram will have no problems with 1080p HD playback as it has onboard an HD 4290 which is the next generation onboard gpu compared to my HTPC which has 0 issues with 1080p playback.
Old December 29, 2010, 02:29 PM
nah, scrap the onboard, get a GTX 580.
Old December 29, 2010, 02:47 PM
and you could help the cpu a bit with a piece of software like corecodec coreavc :)
Old December 31, 2010, 12:12 AM
artistpavel's Avatar
I've always been buying 8400GS for all my HTPCs and non-gaming machines and had no problems, I mean if you gonna get a weak card, why not get the weakest and 0db silent for $25.
Pick apart my proposed HTPC build VanceFox HTPC Systems & Software 17 November 8, 2010 12:00 AM
Help me pick out some htpc components 0o0 HTPC Systems & Software 7 February 12, 2010 10:47 PM
[WTB] A htpc graphics card with s video out and AMD Motherboard Shadowmeph Buy/Sell & Trade 0 August 25, 2009 06:57 PM
IS onboard UMA graphics any good for HTPC? Shadowmeph HTPC Systems & Software 8 July 27, 2009 09:44 PM
Need Graphics Card dozer951 Buy/Sell & Trade 1 September 9, 2008 11:43 PM
