  #61 (permalink)
Old January 19, 2011, 05:32 PM
lowfat's Avatar
Originally Posted by zoob View Post
What are you guys using to overvolt the core? Haven't found anything solid yet besides "use the ASUS BIOS and software".
http://downloads.guru3d.com/Afterbur...load-2604.html
Originally Posted by BigDogg View Post
Anyone able to flash their cards in crossfire? I tried using ATIWinFlash from a command prompt but both cards show 1408 shaders. Before I installed my second card I unlocked the HIS 6950 with a modded 6950 bios and GPU-Z was reporting the shader unlock. Since adding in my second card GPU-z won't show the unlocked shaders. Just wonder if there is a best way to flash both cards for crossfire.
Try using BIOS1 instead of 2. I couldn't flash BIOS2 no matter what I tried.
Originally Posted by Eluder View Post
You have to flash card by card, so remove the card that's already been flashed, do the second one, then plug both back in for CF.
You don't need to do this. Just make sure you select the right card when flashing.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
  #62 (permalink)
Old January 19, 2011, 05:53 PM
BigDogg's Avatar
You mean the switch on the card? Did you use ATIWinFlash ?
I did the command
atiwinflash -unlockrom 0
atiwinflash -f -p 0 modded.bin
atiwinflash -unlockrom 1
atiwinflash -f -p 1 modded.bin
Both still showed 1408 ?
  #63 (permalink)
Old January 19, 2011, 06:11 PM
lowfat's Avatar
I did the command
Yes the switch on the card. I did not use the windows flash. I did it the good ol' fashioned DOS way.
Queen of Dreams WIP
Big Lian Li
Complete
  #64 (permalink)
Old January 19, 2011, 06:35 PM
BigDogg's Avatar
I re-ran the commands in an elevated command prompt rebooted and here is the result:
(Idle is at 55C on both cards now - 2nd GPU is pegged at 100%?)
I don't exactly like the spacing on the UD7. I need to find a longer XFire cable.
  #65 (permalink)
Old January 19, 2011, 07:03 PM
Prolab's Avatar
What's the gadget called to display your video card?
BTW, i dont see both GPU pegged anywhere... it just say 0%
Gaming Rig:
-Caselab STH10, Swiffy MCP35x2, (2) Aphacool UT60 480 rad, HWL GTX 360, Heatkiller IV, i7 5930k @ 4.5 Ghz, 16GB Ripjaws, Asus X99 Deluxe ii, (2) XFX R9 290 w/ XPSC WB, 240 GB Intel 530, 500 GB 850 EVO, (6) 3 TB Tosh HD, EVGA G2 1300 PSU, Win 10 Pro
HTPC Rig:
-G3258 @ 4.0 Ghz, Asrock Z97 Pro 4, Asus 290, 128 GB Crucial M4, (2) 2 TB WD Green, (1) 2 TB Sammy F4, (2) 5 TB Tosh HD, Enthoo Primo, XSPC 480, 240 HWL GTS, Corsair HX620, Win 10 Pro
  #66 (permalink)
Old January 19, 2011, 07:09 PM
BigDogg's Avatar
After i took teh screen shot it went up to 99% but temps didnt? and now it dropped again? I have no idea but whatevre.. going to try oc'ing this Sandy now. GPU-Z is the program there.
  #67 (permalink)
lowfat's Avatar
You are talking about the fan being pegged to 100%? I honestly can't help you there. Have you tried running each card separately to see if it goes away?
I can't even get my POS board to POST w/ both of my cards. Although on their own they seem to be doing 920/1400 w/ 1.2V.
Queen of Dreams WIP
Big Lian Li
Complete
  #68 (permalink)
Old January 19, 2011, 08:27 PM
Prolab's Avatar
I know about the GPU-Z. I was talking about the window gadget below your CPU usage.
Gaming Rig:
HTPC Rig:
  #69 (permalink)
Old January 19, 2011, 09:55 PM
lowfat's Avatar
BigDogg have you tried overclocking your HD6950 SLI yet? If I overclock w/ Afterburner my first GPU stays @ 100% usage until I reboot my machine.
Queen of Dreams WIP
Big Lian Li
Complete
  #70 (permalink)
Old January 20, 2011, 07:51 AM
BigDogg's Avatar
Haven't had a chance to try oc'ing yet. Was having a hell of a time oc'ing my 2600k
Unlock AND overclock at the same time??? cul8erppl Overclocking, Tweaking and Benchmarking 23 June 11, 2011 08:06 AM
GTX570 or HD6970 ? Help me decide please. THS Video Cards 9 December 25, 2010 10:36 AM
Gtx 580 sli vs hd6970 crossfire for 2560x1600 prolymphocyte Video Cards 22 December 19, 2010 11:13 AM
AMD HD6970 pictured... Delavan Rumor Mill 57 December 15, 2010 06:28 AM
AMD unlock phil3_66666 CPU's and Motherboards 5 November 17, 2009 06:46 PM
