Old December 25, 2010, 11:28 PM
Default PCI Express 8x for GTX 460 (768mb)?
Hi, Hardware Canuckers!
I just built a computer 3 days ago, and I'm currently am enjoying it to the fullest! However, I have some nagging questions... such as this particular one: will utilizing the 8x PCI-e slot adversely affect my performance?
My MSI motherboard is not designed very well... while the two PCI-e slots are positioned fairly far away from each other, the 16x slot is way too close to the CPU heatsink that I have installed (a CoolerMaster Hyper 212+). Thus, I installed my graphics card in the 8x slot which is further away from the heatsink. Also, the CPU on the motherboard is located in such a place that it makes the CPU-cutout on the Haf 922 useless... but that's beside the point.
The CoreTemp program reports that my GPU is 24*C at idle and rises up to the low forties when gaming. Will the increase in performance that I might gain from going up to 16x justify the extra heat that my video card will experience?
To clarify, I mean that, because the GPU will be so close to the heatsink (probably 2 centimeters away from the edge of the heatsink), it will most likely have a shorter lifespan. If I can gain a respectable increase in performance (8% sounds good to me), then perhaps I will be willing to subjugate my video card to more pain, albeit reluctantly.
In case anyone is curious, my video card is a MSI Cyclone and my CPU is an i5-760. The temperatures of the CPU range from the low twenties during idle (again, from CoreTemp) to mid-30s to very low 40s during periods of gaming.
Old December 25, 2010, 11:38 PM
the difference is there, but not earth shattering. check this out
GeForce GTX 480 PCI-Express Scaling Review - Page 1/25 | techPowerUp
now thats for a top dog, so id imagine a lower end card be impacted less? :)
GTX 460 768MB or 1GB? ipaine Video Cards 47 September 16, 2010 04:43 PM
GTX 460 768Mb vs HD4890 1GB Nevakonaza Video Cards 14 August 25, 2010 07:04 PM
NVIDIA GeForce GTX 460 1GB & GTX 460 768MB Review Comment Thread SKYMTL Video Cards 126 August 20, 2010 10:01 AM
