<~----> Quadro Driver install? - Hardware Canucks
Old December 19, 2010, 09:45 AM
Slik's Avatar
Default Quadro Driver install?
I just downloaded the 259.81 Quadro drivers from Nvidia site. Is there any thing I should know before I install them? Is there a 'Best' way to install them? Driver cleaner? I just want to make sure, as I have never used Quadro before. Thanks all.
Thermaltake Level 10-i7 3930k @ 4.2ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 1600mhz- Two EVGA Titans SLI - Xonar Phoebus Sound Card-Dell 3008 30" Monitor-Razer Tiamat Headphones-Butt Kicker Gamer-TrackIR 5
Old December 19, 2010, 12:47 PM
SugarJ's Avatar
You shouldn't be using Quadro drivers at all, unless you have a Quadro commercial card. The most current Geforce drivers for your GTX 480's are version 260.99 found here: GeForce.com - Get the Most Out of Your GPU
Old December 19, 2010, 01:08 PM
Well... you shouldn't but people are, since you can run 3dmark 11 in SLI ... some have even said the performance is better than the current nvidia drivers (something with GPU usage in games)... but you have to have an altered .INF file for it to work... I would say just wait until Nvidia releases a new driver...
Old December 20, 2010, 08:17 AM
Slik's Avatar
How about Developer drivers? I have a problem with regular drivers as they lose settings for Physics and color settings every time I start or re-boot my computer. I'm using the 260.99 right now.
Old December 20, 2010, 08:52 AM
SugarJ's Avatar
If you are talking about Beta drivers, there still aren't any newer than 260.99 for 470/480's.
Old December 20, 2010, 10:05 AM
try an older driver too see if you have the same issues... and yes there are no beta drivers out at the moment...
Old December 20, 2010, 10:48 AM
Slik's Avatar
I have a set of 'Nvidia Developer Driver 263.06' downloaded and ready for install if it won't screw anything up. I know I could try it and see for myself but I'm just not comfortable without some info on Developer drivers and the best way to install them. Any and all info is very much appreciated. Merry Christmas!
Old December 20, 2010, 11:16 AM
you won't be able to install quadro drivers unless you mod them or downloaded them pre-modded
i'm using 265.90 on my 580 and no problem so far
just install like other drivers, with the lastest nvidia gui you don't even have to remove the old drivers first, well i don't. I know some people are really anal about drivers but to each their own.
Old December 20, 2010, 12:22 PM
Slik's Avatar
How about the Developer Drivers? Are they the same as Quadro? Are they some kind of beta? Now I REALLY want to try them. I'm not going to until I hear a bit about what kind of drivers they are. Thanks all.
Old December 20, 2010, 12:51 PM
it's just drivers, install them and if it doesn't work uninstall them, there's not much to messed up IMO
Quadro Folding? Dr_BenD_over HardwareCanucks F@H Team 19 May 7, 2010 04:48 AM
Driver install to OS for another PC clone63 O/S's, Drivers & General Software 0 March 24, 2010 09:04 PM
Nvidia Quadro FX Frepz Video Cards 0 January 19, 2010 09:30 AM
Geforce + Quadro enzeo Video Cards 2 September 30, 2008 07:24 PM
ultimate install closed down after install prebent O/S's, Drivers & General Software 0 September 25, 2008 02:05 AM
