Old December 15, 2010, 01:31 PM
Default Witch way to go
I decided to change my video card. My monitor is 1680-1050. I know a good video card is better than 2 weaker ones. The motherboard witch i have supports CF. Since I play COD-BO and CF scaling is good, I want to buy 2xHD6850.
With this new AMD cards i am getting really confused. I don't know what to choose or what my other options are.
HEAT
Overclock.net
RFD
Old December 15, 2010, 01:37 PM
gingerbee's Avatar
at 1650x1050 1 6850 should be more then enough or a gtx 460 which has become my new fav. my2cents
Old December 15, 2010, 01:41 PM
I agree with Gingerbee, since they're both around the same cost. It might help if you look at the reviews for the games you play and see which card scales best.
Old December 15, 2010, 01:44 PM
Buy a used GTX470 which is around $150 last time i saw. Great price for a VERY good card!
Old December 15, 2010, 02:28 PM
Keywork's Avatar
Please direct me at a $150 GTX 470?
Old December 15, 2010, 02:48 PM
I've only seen a used 470 for as low as $200 personally myself. I think $150 is probably below the average going price of a used 470.
Old December 15, 2010, 03:42 PM
i think hes referring to the guy who screwed the plastics on his pair and let them go for 300 ?
i havent seen them for lower than 175-180 usually closer to 200 as per above.
some guy in heres selling a 1gb 460 for that much though.
Old December 15, 2010, 06:24 PM
geokilla's Avatar
According to your sig, you have a ATI 5870. No need to change GPUs to say a 6870 as you're pretty much side-upgrading.
Old December 15, 2010, 07:10 PM
gingerbee's Avatar
ya was thinking the same
Old December 15, 2010, 07:31 PM
Crossfire is a waste at 1680x1050.
A way to know witch version of Windows from the Key MarkOne O/S's, Drivers & General Software 2 November 23, 2009 02:42 PM
Witch Video Card for new build. shammancer New Builds 4 October 15, 2009 04:59 PM
Witch Air Cooler??? jcmaz Air Cooling 10 June 15, 2009 08:49 PM
Strategy Informer reviews Lord of the Rings: TBFME II—The Rise of the Witch-King Supergrover Reviews & Articles from the Web 0 January 4, 2007 06:37 PM
