Old December 15, 2010, 02:34 AM
Default Do you think my warranty is void?
Ok so I thought my new mobo was giving me the POST problems as per this thread: Gigabyte H55M Issues
Turns out that shorting/no boot is the only problem I had.
So what happened was I tested my GTX470 in my original system before transplanting it to the new motherboard. It was working fine up until then. Then I had the shorting issues with the motherboard, prompting me to test other things instead of testing my GPU. So after a while I finally decide to put my GPU back in the old system so I can keep folding with it.
Here's where I find out my card is DEAD. A little frustrated since I was so incredibly careful to avoid PEBKAC, I start returning the card to its stock configuration. I took my ghetto S478 stock cooler off of it and put the shroud back on, then I started to take off the EVGA backplate. To my dismay, I find an oily substance oozing out of the thermal pad that came with the backplate. Not only was it oozing all over the critical components on the back of the PCB, but it was oozing all over the fading warranty labels... Now my card is a Zotac GTX 470, do you think I could actually get a warranty replacement?
TLDR: I have an EVGA backplate on my Zotac GTX 470, the thermal pad on the backplate oozed oil all over the back of the card, fried the card, and started to fade out the warranty labels. Do I have a chance at a warranty replacement?
Old December 15, 2010, 11:42 AM
Theres a slim chance. trying wont hurt :)
My Rig (The Budget Baby)
Motherboard: Asus M4A88TDM-EVO
Cpu: Phenom II X4 955 BE (C3)
Graphics card:Asus GTX 460 1GB (Direct cu)
Cooling: 4 Case fans. Coolermaster 212 plus.
Case: NZXT LEXA-S
HDD/OPTIC: 2X 1TB/Sony 24x
Old December 15, 2010, 12:53 PM
Chilly's Avatar
Pictures?
"Let's face it, we're not changing the world. We're building a product that helps people buy more crap - and watch porn."
Bill Watkins, CEO Seagate Technology
Dual Xeon X5650 @ 4.1GHz | EVGA Classified SR-2
2x4GB G.Skill at 1496MHz (9-9-9-24) | XFX 4890 XXX 1GB at 1000/1000MHz
Intel SSD X25-M 80GB Gen2 | Western Digital 1TB Black | SilverStone Zeus 1200W
Sound Blaster X-Fi XtremeMusic | Sony MDR-V700 | Windows Seven x64
Stuff for Sale! You must buy it, you can't look away!
Old December 15, 2010, 04:44 PM
Pics as requested.
Can't really see it in the pics, but the label has quite a few mildly faded letters, not to mention it's blatantly obvious that the PCB has been soaked in oil if you see it in person. The label is loose as well, it stays on, but it's easy to peel off now.
All the shiny stuff that looks like water is the oil from the EVGA backplate. (or thermal pad to be precise)
And just for kicks theres a pic of my cooling setup.
Old December 15, 2010, 05:02 PM
belgolas's Avatar
Holy crap that scares me of having my back plates on!
This case I would contact both companies. Maybe EVGA will replace the card or maybe Zotac will.
Sponsor a child!
Fight poverty.
Qoute by Perineum
"ID10T. I just BETCHA he's got 9 toolbars on his web browser right now."
Old December 15, 2010, 05:13 PM
r0bc's Avatar
That really sucks....I had no idea there was oil in that pad.
Old December 15, 2010, 05:26 PM
Soultribunal's Avatar
I would personally contact EVGA, and be very reasonable about it with them and see what they say. Anger never works, reason usually does.
ST
www.realhardwarereviews.com
Old December 15, 2010, 07:37 PM
Definitely contact EVGA. They have a very helpful staff. Just make sure you have the invoice uploaded and its registered.
Old December 15, 2010, 08:07 PM
Kommie986's Avatar
WTF? Isn't the backplate supposed to help with cooling? Also, what isn't the pad just a synthetic material? There shouldn't be oil in it?
Old December 15, 2010, 08:41 PM
Looking back, I have no clue how the card could be fried. Thermal pads are usually made out of fairly pure paraffin wax, which should be a solid oil that's completely non-conductive. Having the pad fail and ooze out liquid should be about a 1 in a trillion chance. Even if the pad did fail, the liquid should be completely unable to short circuit my card, considering it should have been in a fairly pure form.
Dark Void coming to the big screen mo' power Gaming 0 December 27, 2009 08:22 AM
ESD and warranty HalifaxJ New Builds 6 March 11, 2009 08:01 AM
some warranty questions. Silvgearx Off Topic 0 January 12, 2009 04:39 PM
This may have voided the warranty Dr_BenD_over Air Cooling 14 October 3, 2008 01:37 PM
Does using an aftermarket heatsink/paste void your intel retail warranty? thenewguy001 CPU's and Motherboards 5 April 2, 2008 03:20 PM
