Old December 7, 2010, 10:40 PM
rjbarker's Avatar
Default Mark11 Fubars Vantage...Fix!
Anyone with 480 / 580 Cards that installed Mark11 today maybe in for a bit of a "wtf" if they try to run Vantage now......very corrupt graphics!
After a Driver Re-install, Re-install of Vantage, finally found the answer over at Evga.com (thanks Falcon)...
uninstall Mark11
System Restore to a point previous to installation of MK11....
From what I understand, FM installs a new Sysinfo File (with MK11) that Vantage utilizes, but its not compatible with Vantage ?!
guess they should have delayed a tad longer...till 2011.. ;)
Further reading on the issue:
3DMark11 installed, run vantage yet?
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old December 7, 2010, 11:06 PM
Arinoth's Avatar
You're not the only one really. I can't run it properly crossfire 6870. It appears in my far right window (in my eyefinity set up) and some very small resolution (cuts off about 90% of the actually visual part of the benchmark) to where i can only see the number of frames. It at least loads both the cards but i can't trust the results as again i can't even see what the hell thats going on on screen.
Old December 7, 2010, 11:22 PM
rjbarker's Avatar
^^ Yeah I had a pretty good OC / run on MK11 and figured I'd give Vantage a go at the same settings......Jane Nash = wtf ?! ....fixed now, but I guess we have to wait for a Patch in order to have both MK11 and Vantage installed at the same time.
Old December 8, 2010, 04:13 AM
Dr_BenD_over's Avatar
The new Sysinfo is borked. It's reading my clocks as 120,000MHZ/140,000MHz. Now if it was 1200/1400 that would be the max clocks my card allows, but it was a stock run at 725/1000.
If it's stupid and it works, it isn't stupid.
Old December 8, 2010, 07:56 AM
I ran a 580 on 3dMark11 yesterday and didn't have any issues with graphics.
Old December 8, 2010, 10:30 AM
rjbarker's Avatar
Enab.....now that you have MK11 installed try a Vantage run.....Vantage is "borked" after installing / running MK11..
Old December 8, 2010, 11:52 AM
Arinoth's Avatar
Don't you love a rushed product?
Old December 8, 2010, 03:10 PM
rjbarker's Avatar
^^^ Apparently this bug only effects Multi GPU's....nv specifically....
I actually got my MK11 Score P7150...uninstallled MK11 and now have my Vantage running properly, so I'll wait and install MK11 again once the "issues" are ironed out.
are you clever to fix anything? CTA Off Topic 2 June 26, 2010 12:20 PM
3D Vantage Results for my i7 2slick4u Overclocking, Tweaking and Benchmarking 12 April 2, 2009 09:29 AM
This is how you fix your Xbox 360 Infiniti Off Topic 7 February 22, 2009 02:26 PM
Dead PSU.. Fix? Infiniti Power Supplies 13 July 23, 2008 08:54 PM
Help Fix NTLDR Gerrich Storage 13 May 6, 2008 06:48 PM
