Old December 2, 2010, 08:27 AM
bvsbutthd101's Avatar
Default Crossfire???
My friend just bought a new budget rig,
My question is will the powersupply he got be able to handle 2 6850's
or 2 6870's. If it can handle it, will the cpu bottleneck
this is the motherboard he got
Newegg.com - GIGABYTE GA-H55M-UD2H LGA 1156 Intel H55 HDMI Micro ATX Intel Motherboard
CPU
Newegg.com - Intel Core i5-750 Lynnfield 2.66GHz 8MB L3 Cache LGA 1156 95W Quad-Core Processor BX80605I5750
Powersupply
Newegg.com - COOLER MASTER eXtreme Power Plus RS700-PCAAE3-US 700W ATX 12V v2.3 Active PFC Power Supply
Old December 2, 2010, 09:00 AM
not quite sure who the oem is, ul lookup just lists cm : QQGQ8.E320127 - Power Supplies, Information Technology Equipment Including Electrical Business Equipment Certified for Canada - Component
but if it can do the specified numbers? why not.
6 series are quite nice on the juice demands :)
cpu will be fine.
Old December 2, 2010, 09:16 AM
he's not getting 2 cards right away, starting off with one, just wanted to make sure the PSU could handle 2, so it's a ok on crossfire right?
Old December 2, 2010, 09:24 AM
should be ok.
Old December 2, 2010, 09:25 AM
Arinoth's Avatar
He should be able to. I am running a 750W Corsair PSU with an i7 940 overclocked to 3.8GHz and with 2 470s i didnt come close to over running my power supply. I've since switched to crossfire 6870s and i believe they use considerably less amount of power then the 470s. Also the i7 1366s use more power then the i5 1156.
If you want i can within the next few days see what my kill a watt meter says it uses during gaming or benchmarking
Old December 2, 2010, 09:27 AM
OK, thanks, he'll be happy to know that :)
Old December 2, 2010, 10:05 AM
Soultribunal's Avatar
I personally wouldn't go above the 6850's on that particular unit. Coolmaster PSU's are...ok...but the OEM they choose is less than ideal. I think the Extreme's were Seventeams low end units. I'm never a fan of pushing a PSU that is less than ideal.
ST
Old December 2, 2010, 12:26 PM
dustin1706's Avatar
I agree with ST in that the PSU is not a high quality unit.
That being said, 700 watts is lots for that system.
Pulling power from my system: i7 930 @ 4.0 | 2x 5870 @ 1000 / 1350 | GTS 450 for physx | 2 HDDs, 2 SSDs, 2 water pumps, fans
According to my kill-a-watt, I am drawing 220w at idle and right around 600w with 100% CPU and GPU load. This is from the wall. Even if my PSU was at it's maximum efficiency of 86%, then my system is actually maxing out at 516w on the DC side.
Rig1 in "My System Specs"
Rig2: Q6600, P5DN-D, GTX650, 4GB HyperX, LG BD drive, TT armor case, ek supreme HF, 655 pump, XP
Dell XPS17 - i7 2820QM, 8GB ram, 1920x1080, BluRay, GT555m 3GB, 240gb Neutron GTX, 640GB Seagate, Win7 64
Server - i5 3450, Asus P8Z77-I Deluxe, 4GB DDR3, LSI MegaRAID 9240-8I, OCZ Vertex 4 120GB, 2x SG Barracuda 3TB(RAID1), 2x WD green 2TB(RAID1), Fractal Design Array R2, WHS 2011
Old December 2, 2010, 01:40 PM
Oh I know 700W is overkill in the traditional sense. But I wouldn't but 100W on a questionable unit. Where as my HX650 I put 85% load right now on the AC side and its quite content.
ST
Old December 2, 2010, 03:12 PM
Dr_BenD_over's Avatar
Not the greatest board for Crossfire seeing as it's x16/x4 (and it looks like the x4 isn't 2.0 even)
If it's stupid and it works, it isn't stupid.
Enough for crossfire? CanadianZX Power Supplies 11 June 20, 2010 06:47 PM
Crossfire being disabled chibi_man O/S's, Drivers & General Software 0 December 19, 2009 12:39 PM
Q regarding Crossfire Jackquelegs Video Cards 4 March 29, 2009 02:52 PM
HIS 4850 ICEQ4 Turbo crossfire or normal HIS 4850 crossfire? lanken123 Video Cards 6 October 7, 2008 09:47 PM
3870 Crossfire Scart Video Cards 6 August 17, 2008 05:14 PM
