Old December 1, 2010, 10:11 PM
Default 5850 vs 6870
Which card should I get? I can get both around the same price, 5850 a little bit cheaper. Performance wise not a huge difference, and I think new AA will introduced to the 5000 series card too, right? If I plan to overclock 5850 would be a better choice?
Old December 1, 2010, 10:17 PM
CTA's Avatar
CTA CTA is offline
get 6870 because its not big difference...
or wait for new amd one at this mid month...
Old December 1, 2010, 10:21 PM
ZZLEE's Avatar
The 6870 will throw off less heat.
Look here HD 6870 & HD 6850 vs. GTX 460 1GB: An Overclocking Study
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
Old December 1, 2010, 10:28 PM
or 6850 and clock it sky high? :)
ASUS Radeon HD 6850 Direct CU 1 GB Review - Page 31/32 | techPowerUp
Old December 2, 2010, 07:54 AM
Oh wow, thanks for the links I never even thought about the 6850 and for the new 6900 it would be overkill for my system, it would bottleneck it I believe.
Old December 2, 2010, 08:00 AM
gameworm's Avatar
I would definitely consider the 6850. It's quite a bit cheaper and isn't that much slower than the others, especially after over-clocking.
Old December 2, 2010, 11:47 AM
Same price? 6870 for sure.
Review Units FS. SKYMTL's Great GPU Sale 2017 - Part 1 SKYMTL Buy/Sell & Trade 1066 December 30, 2017 09:52 AM
XFX ATI 6870 Core Clock weirdness... Dnabb10 Troubleshooting 1 November 23, 2010 01:26 PM
6850 or a 6870 cul8erppl Video Cards 31 November 11, 2010 07:35 PM
3x 9800 GT or 1x Radeon 6870 devilwarier9 Video Cards 6 November 5, 2010 10:26 AM
crossfire 6870 reviews? BrianHanna Video Cards 13 November 2, 2010 03:17 PM
