<~----> Stuck at 2D clocks? - Hardware Canucks
Old November 28, 2010, 04:33 PM
Default Stuck at 2D clocks?
Every so often, my video card refuses to go to its proper speeds when I attempt to play a game. However, I can exit the game, or alt tab from it, load a youtube video, and it goes back up to the proper clock speed. For some reason it will change for youtube but not for my game. Rebooting fixes it, but I don't like having to reboot everytime it happens.
The problem typically starts after browsing youtube or watching videos in general. I can get around the issue by running a youtube video in the background and pausing it, but I'd much rather fix the problem. I've tried leaving hardware acceleration disabled, no fix.
I've tried using MSI afterburner to stop the 2D clock altogether, but it doesn't work. I've also tried updating drivers after using driver sweeper in safe mode to remove the old ones. It still happens. Any ideas?
Specs:
e8400@3.6 ghz
9800GTX+
4GB RAM
Old November 28, 2010, 05:39 PM
Arinoth's Avatar
It may be a driver issue as i found i have to run GPUZ on my system in order for my secondary GPU to report any speeds, temperatures or fan control. Once i run GPUZ and leave it running in the background i get full normal control of it again. Perhaps you should try this yourself?
Old November 28, 2010, 05:59 PM
Ran GPUZ, no fix.
Old December 1, 2010, 01:09 AM
rjbarker's Avatar
Go into your nvcp - Manage 3D Settings - change "Power Management mode" from Adaptive to Prefer Maximum Performance...see if that helps.
Try a couple of different Drivers to find one that works properly.....had this annoyance when I was running 3 x 280's..only mine wouldn't downclock to 2D mode...once I found a Driver whereby they upclocked / downclocked properly I kept it!!
Old December 1, 2010, 08:09 AM
That seems to have worked, thanks.
Old December 1, 2010, 08:54 AM
rjbarker's Avatar
^^^Glad to hear it...
Remember, in Full Performance Mode GPU's will not downclock to 2D Mode (higher temps)..as I said, try a few different Drivers until you find one where "Adaptive Mode" works properly.
With my 280's, I recall all of the 19x.xx series of Driers FUBAR my Adaptive Mode (stuck to 186.xx for quite awhile)....
..btw..welcome to HWC !
Old December 1, 2010, 08:59 AM
Originally Posted by rjbarker View Post
^^^Glad to hear it.....btw..welcome to HWC !
Thanks. I frequently come to this site for reviews and what not so I figured it would be a good place to ask questions.
Old December 1, 2010, 09:03 AM
rjbarker's Avatar
^^^ This is an excellent site for Reviews and Troubleshooting / Advice....tons of "experience" here.....
Everything from basic PC's to high performance gaming machines....
cheers
GPU's have different clocks at idle using Afterburner ??? dustin1706 Overclocking, Tweaking and Benchmarking 2 November 16, 2010 03:14 PM
Precision Tool displays wrong clocks? jcmaz Troubleshooting 4 December 20, 2009 11:31 AM
Forcing 3D clocks on 4890 Supergrover Video Cards 2 November 11, 2009 01:28 PM
cant overclock shader clocks magictorch Overclocking, Tweaking and Benchmarking 2 February 29, 2008 07:29 AM
My 8800 Ultra/ E6600 Clocks Hillsdale Overclocking, Tweaking and Benchmarking 3 December 19, 2007 12:26 PM
