  #21 (permalink)
Old November 23, 2010, 11:26 PM
If I can hold out until the 25th and we get some sales here that would be great. I'm just not sure my card fan will last until then since it gets progressively worse as it runs, but hopefully it can stretch two more days.
ilya - Would I just pull the fan & heatsink off and scrape off the previous paste, remove all screws and metal bits, then bake according to the guide, apply new paste, and fit it back on? If so, I think I can handle that as long as I know how to put all the screws and stuff back :)
Yes, I'm not expecting "real performance" at the $60-range, but until I can save up enough to buy a proper card later, I just need something that will at least play Sims 3 in decent quality since that's my favourite game, and playable quality on my other games like GTA4, Prototype, etc. And something that can handle Photoshop & Illustrator, though I think most cards can do that.
Thanks for the links! Would the Radeon 5450/5550 be similar to the GT 430? I think it is a bit cheaper upfront, but I didn't factor in the MIR yet.
  #22 (permalink)
Old November 24, 2010, 05:23 AM
thank you , for giving this information. even I need a new card.
Play Roulette
  #23 (permalink)
Old November 24, 2010, 01:28 PM
ZZLEE's Avatar
250 nvidia 79 $ after rebates NCIX.com - Buy Zotac GeForce GTS 250 675MHZ 1GB 2.2GHZ GDDR3 PCI-E DVI VGA HDMI Video Card - ZT-20109-10H In Canada.
Woud make a gtood Pysics card if you get somthing better later on.
Cons wont run dx11
drivers are set not likely to updated
"EVGA hunted down the last dozen or so expats living in Karachi." SKY
  #24 (permalink)
Old November 24, 2010, 02:21 PM
Pull off the fan and heatsink, clean everything off with alcohol, put it on some tinfoil balls and toss it in a preheated oven. Suggested times and temps will vary for different cards, your best bet is to Google around and do some research. After you're done just replace the paste on the GPU.
I would consider a 5450/5550 to be a step down from the 430, and the 430 a step down from your 9600GT. The 5450 may have some issues with Prototype/GTA4, it doesn't meet the minimum requirements for Prototype, but any of those cards should handle Sims well enough. In terms of Photoshop and Illustrator, just turn off GPU acceleration if it's too slow, your CPU is pretty good.
If you can afford the GTS 250 ZLEE linked, it wouldn't be a bad choice either as it's a minor improvement over your 9600GT.
  #25 (permalink)
Old November 24, 2010, 03:00 PM
ZZLEE's Avatar
Default Newegg
450 Evga superclocked 123$ Newegg.ca - EVGA 01G-P3-1452-TR GeForce GTS 450 (Fermi) Superclocked 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
  #26 (permalink)
Old November 24, 2010, 03:18 PM
martin_metal_88's Avatar
GTS 450 is far your best choice in a near 100$ price range in the new market. In the used you can have 5770 around 100-110 some time which is pretty leet.
  #27 (permalink)
Old November 24, 2010, 07:34 PM
ZZLEE's Avatar
Default Ncix Sales up
NCIX.com - Buy EVGA GeForce GTS 450 Fermi 822MHZ 1024MB GDDR5 Dual DVI Mini-HDMI PCI-E DX11 Video Card - 01G-P3-1450-TR In Canada.
Rebate to get price. oder on web pick up in store.
Price match the Newegg deal pick up in store Win !
Tom clancy hawk and Starcraft trial
  #28 (permalink)
Old November 24, 2010, 07:46 PM
THAT's a good deal right there ^
  #29 (permalink)
Old November 28, 2010, 06:05 AM
What's a good price for a 1GB GTX 460? As long as it's under $200? Does it matter which brand? I suspect not as long as it's not the Gigabyte SE version, right? (I read the review and I decided it's between a reg. 1GB or I'll just spend about $100 for the GTS 450).
I would like to upgrade by end of Dec. guessing prices might go down temporarily after Xmas? Any chance?
  #30 (permalink)
Old November 28, 2010, 10:53 AM
ZZLEE's Avatar
Boxing Day or there abuots thing should get interesting
rumur dec 12 to 15 things should be interesting to.
video card advice needed drako Video Cards 13 July 25, 2010 11:10 AM
Video card issues......advice needed please. Mumbly Troubleshooting 12 February 21, 2009 01:48 PM
Budget video card advice needed please. Mumbly Video Cards 9 January 17, 2008 05:59 AM
What kind of video card is needed for this LCD TV neurobashing Display Units 1 August 13, 2007 02:02 PM
What kind of video card is needed for this LCD TV neurobashing Video Cards 3 August 10, 2007 02:56 PM
