-   -   GTX580 vs SLI 2xGTX285. Worth it? (http://www.hardwarecanucks.com/forum/video-cards/37966-gtx580-vs-sli-2xgtx285-worth.html)
Dazmode November 14, 2010 12:17 PM
Is it worth to replace dual 285 setup with single 580?
Can't find reference between two... as they too far apart.
Squeetard November 14, 2010 01:24 PM
I say no. A 480 is not woth my 2-260's. Your SLI 285's are gonna edge the 580.
rjbarker November 14, 2010 01:34 PM
^^^ Thats a "loaded" question, they certainly would be "close"...don't want to harp on Vantage (Benching), but I was impressed to see some single 580 scores rolling in at low 30K....my dual 280's did around 26K and 3 x 280's 34K....I think you'd find some very noticeable gains running various games at high Res with Max AA/AF....
personally I couldn't hold onto a few 2xx Series Cards this long....(wish I could) ..... ;)
Really guys it boils down to personal preference...certainly not "right / wrong"
Sagath November 14, 2010 01:42 PM
Bench - GPU - AnandTech :: Your Source for Hardware Analysis and News
480 vs 285 SLI.
Just add about 10-15% on to the 480 scores.
MpG November 14, 2010 01:57 PM
If you're not specifically running into multi-GPU related issues, and have the room for them on the motherboard, I don't think I'd bother upgrading right now.
Soultribunal November 14, 2010 07:49 PM
I echo that sentiment. If it isn't broken, and you are getting the Frames you would like then I wouldn't really worry about it right now. PErhaps when the 570's or 560's (if they come) are out it might be a better option as well.
ST
belgolas November 14, 2010 10:06 PM
Hard question seeing as the performance gains will be small but you do get the benefit of DX11, less power, and probably less noise going to a single card.
If you are currently happy with performance than don't upgrade thats my rule(except I am never happy :haha:).
